oh man another problem, Steering!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2006, 11:07 PM   #1 (permalink)
View rockhard's Photo Gallery
I think my steering pump is on its way out
when the car is going at a slow speed and I turn the wheel the power steering isnt fully working and I can hear alot of squealing.
the pump is run off of the alternator/crank pulley right? could it just be that the belt for the pump doesnt have enought tension and its slipping?
I was told that you should ussualy replace the steering pump when replaceing the timing belt but I did only the belt and now Im probably gonna have to take everything apart again to do the pump Ahhh!!
rockhard is offline   Reply With Quote
Old 11-19-2006, 11:15 PM   #2 (permalink)
View Thraxeh's Photo Gallery
Checked power steering fluid ?
Thraxeh is offline   Reply With Quote
Old 11-19-2006, 11:28 PM   #3 (permalink)
ya Ive checked the P/S fluid it wasnt even registering so I topped it up but the problem still persists
is it very dificult to replace the P/S pump I know that it is located right behind the timing belt/crankshaft, I just want to see if I can get some info before I attempt it
thanks!
Old 11-19-2006, 11:54 PM   #4 (permalink)
View toyomoho's Photo Gallery
Are you saying the pump was suspected of having problems before you replaced the belt? It is possible the belt may just be slipping. The suggestion may have been to replace the water pump when replacing the timing belt. The PS pump is a replace when it fails item.
Old 11-20-2006, 04:22 PM   #5 (permalink)
Gameroom cash: $302555
"could it just be that the belt for the pump doesnt have enought tension and its slipping?"
Probably. That's what it sounds like to me. Retighten the belt and the problem should be gone.
Mike
Mike Gerber is online now   Reply With Quote
Old 11-20-2006, 04:27 PM   #6 (permalink)
theres my problem...
after I did the timing belt I forgot to tighten the tensioner for the water pump all the way so the belt is slipping
thanks
Old 11-20-2006, 06:24 PM   #7 (permalink)
thanks
You're welcome.
Mike
Problem: Steering Locks Up Kriis 3rd & 4th Generation (1992–1996 & 1997–2001) 15 11-20-2006 12:25 AM
Put in a new steering wheel... directional problem...? aaron7 Archived Corolla threads 11 05-25-2006 07:45 PM
Power Steering Problem?? Gandalf Camry & Solara Lounge 4 08-25-2005 10:47 AM
Steering PRoblem reym Archived Corolla threads 12 04-28-2005 03:40 PM
power steering problem 90camryV6 Camry & Solara Lounge 3 07-11-2003 10:47 AM
