1990 Stalls out when it sits a few days. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2006, 06:30 PM   #1 (permalink)
1990 Camry Base
View chubcobear's Photo Gallery
My job requires that I leave my car at work (and drive company car) for a few days from time to time. When I use the 1990 3sfe (140 auto trans.) after these two or three day layovers, the car seems to stall out when accelerated from a stop and runs ratty until it has run for 10 minutes or so. It is almost like it is getting "no gas". After it runs awhile, and from then on (when used daily), it will run perfectly. Does anyone have a clue about this? Vacuum leak? Coil? Any ideas? Thanks for any know how. Chubco
chubcobear is offline   Reply With Quote
Old 11-20-2006, 11:09 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I work at a wrecking yard, and I've had this happen on literally dozens of vehicles. I've never bothered to spend toooo much time diagnosing, because they're just yard beaters, but it's common in older vehicles. As soon as you put the auto tranny in drive, or as soon as you let out the clutch on a 5-speed car, the engine will bog down and die (unless you epress the clutch again). Unfortunately, it could be a multitude of things. Gaskets and o-rings get old, vacuum lines crack, throttle bodies wear-out, and ignition components break-down to reduce efficiency.
If you're really concerned about the problem, or don't have the few minutes to wait, start by cleaning-out the throttle body--this is the simplest and cheapest first step. If that doesn't work, there are just too many other possibilities to list without further diagnosis...
I hope the tb cleaning helps your problem. Cheers!
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-22-2006, 05:20 PM   #3 (permalink)
1990 Camry Base
TBay,
Thanks for the input. Throttle body? OK. I will give that a try. Thanks. Bear
Engine stalls when hot eirik Hardcore Tech and Competition 38 12-19-2004 07:12 PM
1990 Camry V6/AT - O/D Light Flashes yeravgjoe 1st & 2nd Generation (1983–1986 & 1987-1991) 18 02-14-2004 01:30 PM
1990 celica with 150000k on it mhz2010 Celica Forum 3 01-27-2004 12:21 PM
Quality of GT4 Celicas 1990 Tulkas Celica Forum 7 12-01-2003 04:52 AM
1990 V6 Bad Cold Run Problem jtorbitt 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-30-2003 08:23 PM
