91 Electrical Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2006, 04:35 PM   #1 (permalink)
View horgad's Photo Gallery
Everything seems to work fine (headlights, windows, locks, interior lights) until you try to start the car. Then everything goes dead. After 5 minutes or so, the power comes back. If you try to start the engine again, the symptoms repeat. Battery seems strong. Symptoms just started suddenly. Im in the process of checking all the fuses, but I'm think there is a short somewhere. Any ideas would be a great help.
Thanks
horgad is offline   Reply With Quote
Old 11-21-2006, 04:59 PM   #2 (permalink)
View toyomoho's Photo Gallery
First, clean the battery terminals. If no help, check the condition of the wires running from the battery. The terminals at the ends of the wires can corrode, also where wire connects to the terminal.
Old 11-21-2006, 05:05 PM   #3 (permalink)
I figured it out...
Sorry to post before I had looked at it closer, but I was in a panic because I need the car to get to Thanksgiving. It was a real bad wiring job by whoever installed the sunroof. They had a wire going straight into the driver side fuse box and it was causing an arc between two fuses. I yanked the wire out and everything works good now.
Happy Thanksgiving!
Old 11-22-2006, 02:00 AM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
It's nice when electrical problems are so easy to diagnose, isn't it? That could have been hell...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
91 previa transmission problem grego Previa Forum 6 05-20-2011 01:42 PM
Easy fix to steering problem '91 fabbb 1st & 2nd Generation (1983–1986 & 1987-1991) 3 03-19-2007 07:45 PM
Strange electrical problem in 03 Impala Ranger X General Discussion 11 06-04-2005 03:11 PM
electrical problem with 92 Celica King_Mack Celica Forum 0 05-22-2005 01:16 PM
83 Celica Supra GTS electrical problem MrPipes Celica Forum 3 08-14-2004 04:21 PM
