Ok, this is the project.
1 - Eliminate the need for those crappy 3.5" front speakers
2 - keep foot space available
3 - at least retain a semi-clean look
Here's whats needed
1 sheet 1/2 ply or mdf
1 yard of fleese
1 yard of vinyl
3/8ths staples
fiberglass resin
possibly some fiberglass mat
Started off, measured out the area of the lower portion of the door, wanted to eliminate the map pocket. ended up cutting a piece of wood 31" long, and 7" wide. 9" were then left 7" wide, while the rest was cut to 4", so that it would sit along the line of the door.
Followed that by cutting another piece, about 8"x7", then a 3rd piece 8"x2" to use to give the 2nd piece some lift and to let the speaker mount sit at an angle. after cutting the first 2 pieces of wood to shape, rounding them out and cutting the hole for the speaker, i tack nailed them together.
Once tacked together, its time for fiberglass. Started off by tacking a piece of fleese down and pulling it across so that it would leave a slope from the bottom of the board to the top where the speaker mounts, once its all secured on all sides, I mixed up a batch of resin and laid it on thick. I followed that initial coating with 2 more of just resin, straight to the fleese. i decided i wanted a little extra strength, so i layed a few layers of fiberglass mat on the fleese, and then coated it with two more layers of resin. This made a very hard surface, that surely wont crack or move.
After letting it all cure for 24hrs, i sanded the whole thing down and covered it with a layer of fleese. thought this would be a good way to hide some blemishes in the wood/glass and would give the final product a little bit of cushioning.
Then came the vinyl. Fabric store had a gray vinyl very close to the factory gray color. Trimmed it up and stretched it out. This was probably the hardest part of the project, as this stuff doesnt stretch that well. gluing it down doesnt work that well, and it can be a pain if you have curves to cover.
Anywho, this is the final result.
I am considering making another set to sell if anyone is interested. Initial cost of supplies is around $50, and time is the other issue. Probably spent about 12hrs total to make both pods. If someone is interested, lemme know and we'll work something out.
Lemme know what you gen2 guys think.
btw, this is what i had in my old gen2, didnt like them that much, they stuck out too much, didnt flow well and were heavy as they were all wood. These new ones stick out at the most about .5" more than the door map pocket.
http://usera.imagecave.com/c4mry91/door1.JPG
