Solved. Both Fans Run High Speed All the Time - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2006, 05:33 PM   #1 (permalink)
View Variety=Spice's Photo Gallery
1991 Camry V6 Wagon
I spent a few hours over a couple of days this weekend tracing out the fault that caused both cooling fans to run on high speed whenever the ignition was on and whenever the car was running.
I checked all the sensors, relays, and wiring under the hood...everything tested according to spec.
Turns out my problem was the Condenser Fan Control Amplifier located forward of the glove box. 4 screws hold the actual glove box to the dash. One more removes the bracket that keeps the door from opening too far. Pull the box starting at the top, and the relay looking device is right behind it.
A quick trip to the junkyard for the Amp and a motor mount, and all was well in the Camry Continuum again.
Variety=Spice is offline   Reply With Quote
Old 11-26-2006, 06:07 PM   #2 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Congrats on the fix! It's always a rewarding feeling to diagnose and fix something yourself, especially when you can get the parts cheap.
How did you manage to trace it to there? "Fan Control Amplifier"?? Never heard of that,I wouldn't have thought there was any such device in the car... I would have thought it was just a bad sensor or relay.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 11-26-2006, 10:08 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
he is from utah, out here you have to get stuff figured out yourself because there isnt anyone else
Old 11-26-2006, 10:29 PM   #4 (permalink)
Yeah, my father-in-law thought I was a little insane when he saw me tearing out the glove box to fix the cooling fans that were stuck on.
I figured it out using the electrical schematics I found in the e-version of the repair manual posted in the forum. It was a lot of reading, printing, trying to figure out where the components on paper actually were in the car, and head scratching....and it helps to be handy with a DMM.
I like the way the system is designed so that the fans default to the "ON" state when any component fails.
Old 11-27-2006, 07:24 PM   #5 (permalink)
NYR
View IvanHoe's Photo Gallery
My guess is that it's an open circuit and the component is some kind of resistor, so that when it fails, you have an open circuit keeping the "juice" flowing and the fans running constantly.......
Btw, Toyota is always doing things right....
Did you know if you turn the ignition off with the lights on, the lights will go off as well so as not kill your battery?(figured that one out the other day when I got into my car and I noticed that the 'lights' switch was turned on, but the actual lights were off)........Pretty cool. The only time your lights can stay on with the ignition off is if you turn them on after the ignition is turned off.
The Japanese car companies are always thinking ahead.....my former 1992 Mercury Grand Marquis(gasaholic) didn't even have any of the cool features that my current 1988 Camry has.
For example:
Unlock one door with the key, and they all unlock
The headlight thing
.....even cup holders, my Former Mercury didn't even have f-ing cup holders!!!!!!
The only thing that gets on my nerves with the Gen2's is when you 'spritz' the windshield with washer fluid, the wipers dont automatically activate to clean things up
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 11-27-2006, 07:49 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
i think the gen2 cam is the only car that i can remember that opening the door kills the lites, and the wiper washer thing is normal for cars back then without a wiper controller of some kind
Old 11-27-2006, 08:13 PM   #7 (permalink)
NYR
Ive owned alot of 1988 and older cars(as early as 1984), and they all activated the wipers for a short burst to clean things up when 'spritzing' the the window with washer fluid, only the Gen2 Camry is guilty of of NOT doing this in my automotive experiences.
Old 11-27-2006, 08:28 PM   #8 (permalink)
HomeGrown's Avatar
Sweet~ I didn't know that about the fans or the lights! Exellence in engineering.
.... and YEAH, WTF was up with the (lack of) cup holders in the Vic?? I forgot about that until you mentioned it.
Old 11-27-2006, 09:06 PM   #9 (permalink)
actually, the fan relays are "normally closed", allowing power to run to the fan motors unless all the sensors and other components give the right signals and allow electricity to flow to the magnetic coils in the relays, at which point the magnetic field moves the switch, breaks the contact, and prevents power from running to the fan motors. (how's *that* for a classic run on sentence?)
If any single component fails then the relays lose power and revert back to the default 'closed' position, making the fans turn on.
Old 11-27-2006, 09:52 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
none of my yotas did it, no old fords did it, some old gm cars might have though
Old 11-28-2006, 10:59 AM   #11 (permalink)
HomeGrown's Avatar
Hey, I tried the thing with the headlights this morning and they stayed on....
Old 11-28-2006, 04:47 PM   #12 (permalink)
NYR
hmmmmmmm......that's odd.
Old 11-28-2006, 07:27 PM   #13 (permalink)
HomeGrown's Avatar
Why would they discontinue such a great feature?
Old 11-28-2006, 09:11 PM   #14 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
some camry gen2s dont have the lite out thingie
Old 11-28-2006, 10:13 PM   #15 (permalink)
could it be a difference between the Japan-made and the US-made cars?
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
1991 fans run - toggle switch? Montanahelp 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-01-2005 09:03 AM
1991 Camry Fans always run Montanahelp 1st & 2nd Generation (1983–1986 & 1987-1991) 5 12-21-2004 05:02 PM
High Speed Troubles TigerSilhouette General Discussion 10 12-28-2002 10:25 PM
replacing high beam/ day time running Den Camry & Solara Lounge 1 05-16-2002 12:27 AM
