brakes lights and so on.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2006, 08:13 PM   #1 (permalink)
ibaezpardo's Avatar
View ibaezpardo's Photo Gallery
Let me see if I can explain my problem. Camry DX, 91. I can not put any gear. I press the brake, but I can't move the shift. Brakes lights does't work at all. I checked the brake's lights swicth and it is Ok. What can I do?
ibaezpardo is offline   Reply With Quote
Old 11-26-2006, 08:30 PM   #2 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Did you check the fuse box? I can't say for sure, but I thought there was a fuse for the brake lights.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 11-26-2006, 10:06 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
shift interlock
Old 11-26-2006, 11:46 PM   #4 (permalink)
View toyomoho's Photo Gallery
The shift interlock system may be preventing you from moving the shift lever. You should be able to override the lock by pulling out a small plastic tab on the shift console near the shift lever. You should see a white plastic tab; press this tab with a screwdriver, etc while pulling on the shifter. You will need to do this every time you put the lever into park until you find the problem.
Check your Radio, Stop and ECU-IG fuses. Are the brake lights working?
Old 11-27-2006, 09:31 PM   #5 (permalink)
ibaezpardo's Avatar
Yes, I'm using my car now pressing that tab all the time. Brake lights dos not work. I checked the swicth in the brake and is good. I checked every fuses in the box in the driver seat and everything looks good.
Old 11-27-2006, 10:34 PM   #6 (permalink)
Try to determine if power is getting to the stop light switch. If no, this is your problem. Brake light power comes from the Stop fuse, through the stop light switch and to the stop light bulbs. It also goes through the switch to the Shift Lock Computer that controls the shift lock interlock.
