Need help removing the stabilizer bar link - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 10:48 PM   #1 (permalink)
幻影
Phatfantom68's Avatar
View Phatfantom68's Photo Gallery
Exclamation Need help removing the stabilizer bar link
As the title says, I'm trying to take out my rear strut, but the bolt is weird as hell, and the FSM (online) doesn't mention anything about how to take the weird-ass nut/bolt/rivet thing off.
Sorry about not knowing the technical term, but yeah... I need help to get this sh*t off, because I HAVE to have this project done by Friday.
1991 Lexus LS400 (UCF10)
1991 Toyota Camry DX (SV21)
1984 Toyota Celica GT (RA64)
1994 Ford F250 XLT
Phatfantom68 is offline   Reply With Quote
Old 11-30-2006, 01:01 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
u get an allen wrench and u use a open 14mm wrench to take it out
Old 11-30-2006, 11:22 AM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
This is a really tricky job...once they get old and rusty, those nuts do NOT want to come off. Be really careful with the allen wrench, because if you strip the head of the bolt (the way I did on both my Camry and my GTS) then you'll have to saw the damned thing off and buy new ones. The linkages are $100 EACH and they're dealer-only. Use lots of penetrating oil for a day or two before you try to loosen the nut.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-30-2006, 04:49 PM   #4 (permalink)
Gameroom cash: $302555
Do what the others have suggested. Soak it liberally in a good penetrating oil before trying to remove it. I would do it for 2 days straight and then drive it to help the penetrating oil work it's way in and do it's job. When trying to remove it, you hold it with an allen wrench in the center while turning the nut. If it does break, NAPA carried the "sway bar end links" for my 98 Camry. They were around $60.
Good luck.
Mike
Old 11-30-2006, 09:13 PM   #5 (permalink)
幻影
Alright... well... I don't have metric wrenches (only sockets), so I'm leaving the back of the car stock for now. I'll get around to doing the rears in about a week or so, but right now, I need to hook up my front brake lines and bleed the system and I should be good to go. Car does look a little weird being raked though... slammed in the front, stock out back.
Also, when I was playing around with the strut in the back, it seems that the sway bar/stabilizer bar gets in the way of removing it from the axle hub thing (sorry, I don't know my technical terms). Is there a trick to getting this off, or will I have to take the motherfucking sway bar off too?
1994 Ford F250 XLT
Old 11-30-2006, 10:17 PM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
just smack the hub assembly out of the strut and it'll drop out leaving u room to take the strut out of the car
Will a front anti-sway bar swap from a V6 to 4 cyl. ? nogard Camry & Solara Lounge 3 06-15-2006 10:56 PM
Sway Bar for JDM Gen5 sqcamry2003 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-05-2005 12:25 PM
legit, or crap, strut bar felkajamine Camry & Solara Lounge 31 03-04-2005 10:17 PM
gen3 SE stabilizer bar? 87Camry5Speed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-07-2004 07:24 AM
need sway bar link pukemaggot Camry & Solara Lounge 1 02-02-2004 12:23 PM
