loud clicking/popping/crunching sound coming from right front wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 11:05 PM   #1 (permalink)
View mi_carro's Photo Gallery
When I make right or left turns, the left front wheel of my 88 camry makes a loud popping/crunching/clicking noise? What is it? The same sound was coming from an old Tercel that owned and when the parts were pulled apart and examined, the component that held the bearings together was messed-up. Could be the same? I've been doing my homework and read that it could be the CV Joint... true? Any suggestions. Could I do it myself? Could it be a one day deal? How much would a mechanic charge if they did it? Could they do it in one day? Please help!!!
Thanks,
Fredo
mi_carro is offline   Reply With Quote
Old 11-29-2006, 11:37 PM   #2 (permalink)
View Kingdom934's Photo Gallery
A noise like that while turning or even going slowly is a sign if bad CV joint(s). For all I know, it's pretty costly.
This is usually caused if the CV boot (that protects and keeps the grease in and rubish out) around the joint is torn for a decent period of time. I would check if the CV boot is torn.
Kingdom934 is offline   Reply With Quote
Old 11-30-2006, 12:15 AM   #3 (permalink)
View nuron's Photo Gallery
What if the CV boot is not torn? Mines does the same thing intermittently.
nuron is offline   Reply With Quote
Old 11-30-2006, 12:50 AM   #4 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
boot doesnt have to be torn for the joint to be bad.
CV's arent hard to replace. replace the whole axle, not just the joints. basic tools and a breaker bar are all youll need. Think they're about $100 just about anywhere.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 11-30-2006, 11:28 AM   #5 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
^^ Yeah, the nice thing about these cars is that you can remove/replace the driveaxle without removing the hub. It only takes about an hour or two for a first-timer to replace, but be careful prying the inner end our of the transmission...don't hammer on it or anything or you'll damage the output shaft/gear.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-30-2006, 04:51 PM   #6 (permalink)
Gameroom cash: $302555
If you take in to some place like Pep Boys, they charge around $200 to replace the whole axle with a rebuilt one.
Mike
Old 12-20-2006, 03:42 PM   #7 (permalink)
CV joint grease?
If I replace the cv joint myself, what type of grease should be used? Someone told white high temperature grease?
Old 12-20-2006, 08:29 PM   #8 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
If you want to replace the CV joint instead of the axle (which I do not recommend) the joint will come in a box with a boot, two clamps, and a ration of grease.
Do the axle.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
clunk coming from front end redstu 2nd Generation (2005+) 8 05-09-2008 02:18 PM
Why does my manual say my '06 is front wheel drive? HotRod53 2nd Generation (2005+) 1 11-17-2006 08:14 PM
Front Brake nocking sound ikolenchenko General Discussion 2 09-06-2006 12:13 PM
Front wheel bearings john Archived Corolla threads 10 04-20-2006 04:03 AM
