Hi I am new to the forum
I have 1991 Lexus ES250 V6 160,000+ miles
Check engine light came on after some exhaust down pipe works most likely coincidence
Wisconsin car, O2 sensor (1 sensor only I believe) and TWC original still.
Tried to clear the check engine light by disconnecting the negative terminal of the battery and by pulling the 15A EFI fuse but the light will came back on shortly when engine rpm goes to 2000 rpm driving forward.
By the jumper method: the code is 21
=Oxygen sensor and heater circuit
I took the car into smog testing station and analysis is OK on CO, OK on HC but failed NOx at twice the level.
Smog testing station also print out A/F mixture lean.
Maybe someone with more experience can help me :
1. Do I have a flinge type sensor or screw type
2. The O2 sensor is on the exhaust manifold on the passenger side, blocked by many things. What is the best way to get to the part? Jack up the car/ drive it on ramps/ or jack up the car and remove the passenger front tire to get to the part.
Kind of cold on the ground now!
Thank you
