Girl replaces timing belt ^^
Thanks for the info. I checked the rotor inside the distributer before and it rotated just fine. I then tried many other misc. things to try and get it running. I then removed the timing belt cover anyway to double check, and it had slipped three teeth. I proceeded to remove and replace my timing belt, where my cousin and I, discovered that it was the sproket that runs the water pump became loose and made the belt skip. So I had to replace the water pump as well, so after 81/2 hours of labor, and a new battery. My car now runs. Thanks for your advice ^^
Jenn
