ignition switch and lock removal tips - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2006, 08:18 AM   #1 (permalink)
View smkdwnn's Photo Gallery
2nd Generation ignition switch and lock removal tips
Any tips on how to remove the ignition lock and switch on the gen 2 camry?
smkdwnn is offline   Reply With Quote
Old 12-10-2006, 10:54 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the switch just bolts to the end of the tumbler, but the tumbler is another story, whats going on?
Old 12-10-2006, 12:42 PM   #3 (permalink)
2nd Generation
it seems like the ignition switch is worn out. turn the key, no crank at all.
have a rebuilt starter and new battery and terminals installed a few months ago.
Old 12-10-2006, 02:25 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
you got power on the small wire at the starter when cranking?
Old 12-11-2006, 06:34 AM   #5 (permalink)
haven't tested that, when it does crank it starts, it usually cranks when i turn the key though only a few times it doesn't crank
Old 12-11-2006, 07:31 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
test time
Old 12-12-2006, 06:18 AM   #7 (permalink)
aussie_gen1's Avatar
View aussie_gen1's Photo Gallery
but i haven't studied
aussie_gen1 is offline   Reply With Quote
Old 12-13-2006, 09:19 AM   #8 (permalink)
View ozzi's Photo Gallery
Camry Start Circuit
If you get clicks with a good battery and starter, it is a bad circuit/connector. Run aux circuit/switch between the hot post and crank connector on the starter. Mount switch under dash. I have fussed with this years. Toy mech says he had family Cressida with issue and fixed with aux circuit. Or you can replace harness.
ozzi is offline   Reply With Quote
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
how to program keyless remote for '07 CE? MaximaPower Archived Corolla threads 5 03-02-2007 07:41 PM
