88 camry crankshaft bearing change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2006, 02:06 PM   #1 (permalink)
View motocam25's Photo Gallery
Just aquired an 88 camry. Do not have it here with me yet, but the motor is a 4cyl and has the number 2000 on it. Anyway, the guy I bought it from said the crankshaft bearing is out. It starts and runs, but you can definately hear the bearing if you rev it up a little. He said you can change it without removing the engine. Any truth to this?
Thanks in advance. Nice forum by the way!
Moto
motocam25 is offline   Reply With Quote
Old 12-12-2006, 02:41 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Prior to tearing into the engine verify the noise source!
Doctor J is offline   Reply With Quote
Old 12-12-2006, 06:51 PM   #3 (permalink)
Well I went and listened to it again. It is definately in the lower end. And it knocks HARD and loud if you rev it up a little.
Thanks
Old 12-12-2006, 07:28 PM   #4 (permalink)
View toyomoho's Photo Gallery
If the engine is knocking it is most likely a rod bearing. It is possible to change it out with the engine in the car but the crankshaft journal must not have been damaged from being hammered. The longer you drive it, the more potential for damage.
Old 12-12-2006, 08:38 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
if it is good and loud the crank is probably history and the big end of the rod egg shaped and hammered
Old 12-16-2006, 05:27 PM   #6 (permalink)
View marc780's Photo Gallery
What fredk said. Dont try to patch it, for a proper repair the crank has to come out, , the journals inspected for excess wear and damaged, and miked for diameter etc.
I'd be thinking you need a remanufactured long block at least..., sorry but theres no point in doing any half measures for a crankshaft repair unfortunately.
Old 12-16-2006, 06:39 PM   #7 (permalink)
NYR
View IvanHoe's Photo Gallery
I say avoid buying it, sounds serious. There are plenty of Gen2's around......dont settle!
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
88 Camry wagon all trac conversion Jimbologist 1st & 2nd Generation (1983–1986 & 1987-1991) 4 04-07-2005 09:49 AM
A Camry with no Tranny oil change TaxiDriver Camry & Solara Lounge 18 05-18-2004 07:09 PM
