88 3sfe & tranny questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2006, 08:47 AM   #1 (permalink)
View Montanahelp's Photo Gallery
I did it again. I bought another project Camry. It has an automatic tranny that is bad. It barely moves in forward or reverse. The fluid was overfilled when I bought it. I was looking at my repair manual and it said the tranny pump screen could be restricted, and needs to be cleaned. Its a long shot but has anyone ever seeing this be the cause? My thoughts are that if the fluid wasn't pumping properly it would fry the clutches in the tranny. I have another tranny I was planning on putting in, but I like the idea of cleaning the screen much more than swapping the tranny.
It also appears to be leaking coolent from the front of the engine above the oil filter. There are a couple of metal tubes that go to the thermostat housing? I can't tell if it is the thermostat housing or where the tube attach. Has anyone seeing this before?
Thanks for looking. THIS FORUM HAS SAVED ME TIME AND MONEY ON MANY OCCASIONS!!!!!!!!!!
Montanahelp is offline   Reply With Quote
Old 12-16-2006, 11:47 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
One of the tubes from thermostat housing has rubber o-ring, that leaks.
Drop the transmission pan and look for metal deposits there.If the car moves normally in low or second position, the direct clutch may be damaged.
Doctor J is offline   Reply With Quote
Old 12-17-2006, 06:14 PM   #3 (permalink)
Toyota Veteran
View ironpig's Photo Gallery
Start looking at the Solenoids. Pull the codes watching the O/D light and it'll piont you in the right direction.
1990 Hilux Surf 1988 Camry SE-X
ironpig is offline   Reply With Quote
Old 12-18-2006, 09:12 AM   #4 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Code procedure:
http://www.toyotanation.com/forum/t170746.html
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
88 Corolla auto tranny swap dx-r Archived Corolla threads 8 03-27-2007 09:55 AM
'88 Camry 3sfe husker Vehicles 1 09-16-2005 12:53 PM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
Ahhh... tranny questions will the 3sfe tranny fit the 5sfe WickedWerx 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-13-2003 08:42 AM
ATTN: Darryt - manual tranny questions Ratko Hardcore Tech and Competition 0 05-01-2002 10:25 PM
