Power window & door fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2006, 08:41 PM   #1 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
Does anyone know where the power door and window fuse is located for a 91 Camry? I searched the forum, as well as checked the fuse box under the hood and in both kick panels. I also took apart off the driver side dash and can't seem to find it. Any help is appreciated, it's annoying not being able to use my key fob or put the windows down! Thanks.
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 12-21-2006, 09:58 AM   #2 (permalink)
View matt_s's Photo Gallery
I had a similar problem with my 89 cam. I couldn’t use any of the controls in the driver’s side door but I could lock the car with the passenger door. I couldn’t roll down any windows. What I did was I took off the driver’s side door panel and I tested all the grounds that are in the wiring harness and I had to fix one and know it works. You can try that but if that doesn’t work I don’t know, sorry.
Matt_s
matt_s is offline   Reply With Quote
Old 12-21-2006, 01:01 PM   #3 (permalink)
Gen2 Camry
I'll check that out but I think it's the fuse. None of the door locks or windows work from anywhere in the car.
Old 12-21-2006, 04:21 PM   #4 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Here is a place to start:
http://tril.shineautoproject.com/camry/90/index.html
Scroll down to Electrical Wiring Diagrams
and go to page 99 of the pdf file once it loads.
There is a 30 a CB that feeds a power main relay, and on through the harness into the door. You will see where you should find power, and work back toward the relay from there.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 12-21-2006, 11:14 PM   #5 (permalink)
View toyomoho's Photo Gallery
Power window fuses: Power No 1, ECU-B, ECU-IG. Door lock wireless: Dome, Door1, ECU-B. Also check ECU-IG. Look behind ashtray in lower left dash drivers side, in front of where you left knee would be.
Old 12-23-2006, 11:45 PM   #6 (permalink)
Gen2 Camry
Timebuilder,
That 30A CB was the culprit. I changed it out with the one from the rear defroster until I can pick up a new one. Thanks for the help.
1993 power window short on driver side fix? steve273 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-13-2007 08:53 PM
Power window woes loonmobile Camry & Solara Lounge 0 06-27-2006 05:47 PM
Power window adjustments...HELP kevintomb Camry & Solara Lounge 8 08-23-2005 05:55 AM
Stuck power window hdsalinas Archived Corolla threads 3 03-18-2004 08:46 PM
