1990 LE V6 Shudders - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2006, 09:05 PM   #1 (permalink)
View boomerboy's Photo Gallery
1990 LE V6 Shudders
I have a Camry 1990 LE V6. When the car gets close to normal operating temperature in high gear (when the car starts pulling) the engine starts shuddering and won't gain any speed. I've replaced spark plugs/wires, checked the cold start injector, and I don't know what else to try. The car runs fine at any other time.
I have a Haynes manual that doesn't answer my question. It only says it could be in the drive axles, but I think it's an engine problem.
Any ideas?
Thanks!
boomerboy is offline   Reply With Quote
Old 12-21-2006, 11:28 AM   #2 (permalink)
Ancientwolf13's Avatar
View Ancientwolf13's Photo Gallery
Your problem could be with the fuel filter or air filter if you already changed the spark plugs and wires. These will throw off the ECM and could be the source of your shudder in high gear due to the change in the fuel and air mixture to compensate for the bad circulation. Give those two a try since they should be replaced now and then anyway.
Other than that I'm not sure what your problem is because I can't see what exactly it does and where the problem.
Ancientwolf13 is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
My 05 I4 XLE vs 07 V6 LE Comparison moeharri 5th & 6th Generation (2002-2006 & 2007-2011) 26 05-24-2006 09:24 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
