» Site Navigation
» Buyers Guide
» Network Links
1st & 2nd Generation (1983–1986 & 1987-1991) Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
12-21-2006, 12:03 AM
#1 (permalink )
5spd TPS problem?
3sfe 5spd. im not too sure of this tps check. i did what the haynes manual says to dignose the tps and it seems correct.
i get no code at idle but when rev up, tps code comes on. the problem is that my rpm bogs up and down at around 1.5k rpm. everything else is normal.
is the 3sfe tps 5spd on the celica same as the camry?
-03 Matrix XR
-90 Celica turbo Alltrac
12-21-2006, 08:30 AM
#2 (permalink )
ASE Master, now Realtor
I don't know.
You could ask about the two tps applications at the toyota parts counter and see if they have the same part number assigned to them.
Courage...Honor...Conquer
12-21-2006, 10:54 AM
#3 (permalink )
Where's my boomstick?
There are 2 different ones, youll know when you pull yours off and compair. the 2 cant be swapped.
The 87-88 i believe had one type and the 89-91 had a different one. Celica probably used the older one.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
12-21-2006, 09:09 PM
#4 (permalink )
TOmmy: is your 5spd camry throwing the same code if reved? im j/w... urs is a 3sfe?
-03 Matrix XR
12-21-2006, 09:21 PM
#5 (permalink )
what code are you talking about? and yes, 3SFE
My garage
12-21-2006, 11:07 PM
#6 (permalink )
well mine at idle it doesnt throw any code but when i rev the engine then the tps code comes on. i dont know if thats normal.
-03 Matrix XR
12-21-2006, 11:38 PM
#7 (permalink )
how are you reading the codes? they're supposed to be read with the car in the on position, and terminals e1 and t on the diagnostics port bridged.
just go to the junk yard and grab a tps. they can be a pain to get off though.
My garage
12-22-2006, 08:24 PM
#8 (permalink )
yes the engine is on, diganose terminals are shorted. im getting a normal code at engine idle. but when rev up pass 2k or so tps code comes right on and if you let it sit back on idle for about 30 secs to 1 min the code clears back to normal. now that part i dont know if thats normal. thats why im asking if yours would do the same.
i went to the local junk and there was 6 4cyl camry but all auto. 1 celica with 3sfe but auto.
-03 Matrix XR
12-22-2006, 08:30 PM
#9 (permalink )
JUST RE ENGINEER IT
pull the codes key on engine off
12-22-2006, 08:43 PM
#10 (permalink )
confused here... u mean read the codes with engine off?
if so... its none. but when reved up will it give a tps code...?
-03 Matrix XR
12-22-2006, 10:37 PM
#11 (permalink )
just replace the damn thing and get it over with.
My garage
12-22-2006, 11:55 PM
#12 (permalink )
JUST RE ENGINEER IT
you tell em tommy, but you really do the codes koeo
12-23-2006, 06:44 AM
#13 (permalink )
NYR
The 5 speed tps is actually built into the throttlebody......= major P.I.T.A. to take off!
1991 Corolla LE - 5 speed
12-23-2006, 09:52 AM
#14 (permalink )
Codes;
Go here:
http://oregonstate.edu/~tongt/camry/
Click on "EFI"
after the pfd loads, scroll down to pdf page 23.
As you use each section in the link list, create a copy for your hard drive, and save yourself time and their bandwidth.
12-23-2006, 06:51 PM
#15 (permalink )
so yours dont throw codes when engine rev up with dignose terminal shorted?
-03 Matrix XR
Linear Mode
