My cam.....15 years - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2006, 04:31 PM   #1 (permalink)
Toyota 4 Life
TravisAe86's Avatar
View TravisAe86's Photo Gallery
Japan My cam.....15 years
My dad had brought my cam since 92 and know it is now 07 and it have never gave us any problems. Just shows toyota Qulity 15 year oh wear and tear in New York and this is the first porblem. I go to start it up but it wont turn over. This guy comes and gives me a jump but it still does not start up, it sounds like it is trying to turn over but it can't. I just got a new igition for it so it can't be that, can it be the battery?? i have to get a new one i guess. I just got the car painted Forest Green, got new 16' rims and new wheels. it looks so good. Have to get some pics of it up. I am working on looks first then i was going for peformance. I was going to get a new battery first and see if it will work. I will keep u updated.
TravisAe86 is offline   Reply With Quote
Old 12-31-2006, 06:16 PM   #2 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $654020
View 84Cressida's Photo Gallery
Could be the starter..
1994 Toyota Pickup Xtra cab 4x2 22R-E 44,000 mi
1998 Toyota Avalon 1MZ-FE 137,000 mi
2005 Chevrolet Silverado Crew Cab 49,000 mi
2006 BMW 330i Sedan 85,000 mi
2007 Toyota Camry Hybrid 2AZ-FXE 62,000 mi
As of May 17, 2011. DEATH TO SCION!
84Cressida is offline   Reply With Quote
Old 12-31-2006, 10:17 PM   #3 (permalink)
View boi_si's Photo Gallery
seems like u said it cranks but wont fire right up...
check fuel pump... are u geting fuel. possibly checking diagnose codes first to see if ECU catches any bad sensors. are u getting spark? distributor cap, rotor, and coil all good?
if battery doesnt have juice it wouldnt crank.
-03 Matrix XR
-90 Celica turbo Alltrac
boi_si is offline   Reply With Quote
Old 01-01-2007, 04:35 PM   #4 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
Why is this in the Toyota News forum? Holy hell
And it does sound like the car is cranking, so it will not be the starter. You need to now determine whether you're not getting air, spark or fuel.
You also just got a new ignition: what parts specifically?
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 01-03-2007, 01:27 AM   #5 (permalink)
View marc780's Photo Gallery
So i'm hearing you say the condition is that it won't crank at all. Which of course is different than the conidtion called "cranks but wont start". So the starter doesn't turn the engine over and this means the problem is a lot simpler.
If you don't know how old the battery is i'd assume the answer is probably it's TOO old. But have it tested first - after charging (and with engine off) a strong battery is from 12.6 volts or more, 12.4 is marginal and about ready to die in a little while.
It's also possible the alternator is not charging the battery too, so check that as well. If you can get a volt ohmmeter you'd want to see 14.0 volts at the battery, with the engine idling.
Old 01-03-2007, 06:43 AM   #6 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
But with a jump it should still turn over, even with a bad battery, unless the jumper cable connection isn't good.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
5efe adjustable cam gears....group buy in the making kene Yaris, Vitz and Echo Forum 0 06-24-2004 01:47 AM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
Pics of my CAM NOTSOFAST Camry & Solara Lounge 9 04-22-2003 08:49 PM
