86 camry oil amount and weight - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2007, 04:42 PM   #1 (permalink)
I hate rust!
View Abram86's Photo Gallery
2nd Generation 86 camry oil amount and weight
I have an 86 camry, it didnt come with an owners manual and its past due on an oil change.
I looked all over under the hood and it doesnt say it, im sure because it sat in an old ladies garage and its nice and clean under the hood
so what weight and how much?
Im guesing its like 10w40 or somthing
Abram86 is offline   Reply With Quote
Old 01-09-2007, 04:56 PM   #2 (permalink)
TN User
luvmybeater's Avatar
View luvmybeater's Photo Gallery
5W30, 3.9 quarts
'91 Camry 2VZ-FE, auto
'91 Celica 4A-FE, 5 speed
N.E.G. Web Design
luvmybeater is offline   Reply With Quote
Old 01-09-2007, 04:59 PM   #3 (permalink)
New older TN User
WhiteCrown's Avatar
View WhiteCrown's Photo Gallery
We had an '85 Camry. If it's the same engine (2.0L) I think it was 4.2 qts of 10W-30. I can check when I get home . . .
WhiteCrown is offline   Reply With Quote
Old 01-09-2007, 05:18 PM   #4 (permalink)
I hate rust!
yeah its a 2 lieter, I think, it says 2000 on the intake manifold
Old 01-09-2007, 05:25 PM   #5 (permalink)
View MattSWE's Photo Gallery
2nd Generation
I have a 91 DX and use 10w30, what would switching to 5w30 do for me? I have 147,000k btw on mine.
MattSWE is offline   Reply With Quote
Old 01-09-2007, 05:32 PM   #6 (permalink)
I hate rust!
lol you would burn more oil
Old 01-09-2007, 08:13 PM   #7 (permalink)
New older TN User
WhiteCrown's Avatar
I'm looking at the owner's manual and it does say the oil capacity is 4.2 qt (with filter change) for the 2S-E engine. The viscosity is more complicated:
I used 10W-30 for most of the life of the car, I switched to 10W-40 as the engine got looser. With 10W-30, the oil light would take a long time to turn off right after starting the engine. 10W-40 was better.
MattSWE:
For the above reason, I would not use too thin of an oil on a high mileage engine. You could try 5W-30 and if the oil pressure is not too low, you should be OK.
Old 01-09-2007, 09:15 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the thinner the oil the noiser the motor is going to be
Old 01-10-2007, 09:21 AM   #9 (permalink)
I hate rust!
sry i drive an 87 not an 86 camry, and it has 97k miles on it should i use 10w30 still?
Old 01-10-2007, 02:45 PM   #10 (permalink)
Gameroom cash: $302555
I owned an 86 Camry with the 2SE 2 liter engine for many years. 4.2 quarts is correct, however, it may require only 4 quarts depending on the capacity of the filter you use. I would put in 4 quarts and then start and run the engine for a few minutes and then shut it off, wait 10 minutes and then check the oil. 4 quarts will probably fill it. When Toyota published that 4.2 quart figure in the manual, they were using a larger stock filter than is available today. I believe the filter I used was the Fram PH2951. Also, I always used 10W-40 oil.
Mike
Old 01-11-2007, 09:13 PM   #11 (permalink)
New older TN User
WhiteCrown's Avatar
The best oil to use is what the Owner's Manual recommends.
2007 Super White Camry LE, i4, auto; replaced our 1985 light beige Camry DX at 217,983 miles.
Old 01-13-2007, 11:06 AM   #12 (permalink)
I hate rust!
yes which i dont have
Old 01-13-2007, 03:11 PM   #13 (permalink)
Infrequent Tourist
Nice89's Avatar
View Nice89's Photo Gallery
2nd Generation
10W30 is fine for most climates. If you live in snow country and drive short distances, then the 5W30 might give you better lubrication during all those cold start ups.
When I lived in the Boston area, my cars had no problem starting with 10W40. I never worried about oil grade and temperature.
I run 5W30 full synthetic in my 89 3sfe. It works fine with minimal oil consumption, mostly due to a few small external leaks. My car has 64K miles on it. I drive it a lot so the oil is changed every two months (about every 4k miles).
I think people get carried away on these oil decisions. The enemy of your engine is sludge. Cheap oil will have more sludge forming chemicals in it than the best synthetics like Amsoil, Repsol, Spectro, etc.
Those high end oils can be expensive, but stand up better to long oil change intervals like I do. For me, top quality oil is cheap compared to the labor for a service station to change it. With 2 jobs and night school, I don't have time to DIY.
You can get similar results with cheaper oil like Mobil, Shell, Chevron, and Valvoline dinosaur oil by changing with a new filter every 3k miles.
How many miles will it go?
Nice89 is offline   Reply With Quote
Old 01-20-2007, 03:15 PM   #14 (permalink)
1990 Camry 5SPD
Skell's Avatar
View Skell's Photo Gallery
just did an oilchange in 90' 4cylinder.. with 10w30 used 4bottles (4qts) w/new oil filter
should i really be concerned about the ".2" i didnt put in? id have to buy another bottle....
drove around the block and everything seemed fine...
90 Blue Toyota Camry 5SPD - current
00 Blue Subaru Impreza 2.5RS 5SPD - sold
00 Black Honda Accord EX V6 AUTO - trade in
88 Brown Toyota Van EFI AUTO - sold
Skell is offline   Reply With Quote
Old 01-20-2007, 08:45 PM   #15 (permalink)
New older TN User
WhiteCrown's Avatar
As long as the oil is between "Low" and "Full" on the dipstick, you're OK.
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
Amount of roof rack weight? colinb xB Lounge 0 11-09-2005 01:22 PM
Need very hot temperature motor oil suggestions. Blek General Discussion 20 07-15-2004 09:59 PM
