alittle help on a engie - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2007, 02:44 PM   #1 (permalink)
89 camry dlx
View richy2kool's Photo Gallery
USA alittle help on a engie
hey whats up people.......if you dont know i have a 89 camry dlx all-trac and i want to change the engine and heres what i found and im not sure wich engine to chose or wich one works a little help would be kool
Celica Turbo2.0L48/87-8/893SGTEDOHC, Turbo, All-trac, 8 bolt flywheel with 10mm bolts, internal EGR1709 250Celica All-Trac2.0L49/89-10/913SGTEDOHC All-Trac & AWD, Turbo, 8 bolt flywheel with 12mm bolts, internal EGR, 7 bolt exh manifold1439 100Celica All-Trac2.0L410/91-9/933SGTEDOHC, All-Trac Turbo, 8 bolt flywheel with 12mm bolts, internal EGR, 9 bolt exh manifold1709 300
richy2kool is offline   Reply With Quote
Old 01-11-2007, 07:57 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
You can get any of them to work... Don't forget you need a ton of stuff other than just the motor... Wiring harness, AFM, coil, ignitor, etc... Then you actually have to do the motor swap (and associated wiring).
-Charlie
Old 01-11-2007, 09:06 PM   #3 (permalink)
89 camry dlx
i see that you have one done...is there any way you can give me a list of the stuff i would need to make the motor work and what tranny would i use...i would love to change it to stick but if thats to much work then i dont know if i should bother
Old 01-12-2007, 12:57 PM   #4 (permalink)
white90dx's Avatar
Whoa... if you have an auto, you pretty much have to swap over to a manual transmission - the auto will likely not handle the power, and you have to deal with the transmission control (which is at least partially integrated into your current ECU). The 3s-gte was never attached to an auto from the factory.
Get a clip and you will be happier...
-Charlie
Old 01-12-2007, 01:02 PM   #5 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
A "clip?"
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-12-2007, 03:17 PM   #6 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
^front clip, take car, cut off everything infront of the a-pillar and thats a clip
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 01-12-2007, 03:40 PM   #7 (permalink)
I wasn't sure how a front end clip would apply to what he wanted to do. Is that a common way of upgrading a Camry, with a different front end, firewall forward?
Old 01-12-2007, 05:14 PM   #8 (permalink)
89 camry dlx
ok...im not sure what a clip is.....but you did answer my question....im just going to look for a car with a 5-speed and up grade that and keep this one for parts....but i still need some info on how to go about doing it and what parts i need and what to upgrade....im not going to give up on this
Old 01-12-2007, 06:51 PM   #9 (permalink)
Tommy's Avatar
reason you get a clip is to be sure you have EVERYTHING you need. its like having a parts car to pull from.
I think you should do something to the all-trac. youll need to upgrade the transmission anyways if you want to do the swap, oh and btw - look to spend at least $5k on this, and up to double that.
My garage
Old 01-12-2007, 07:23 PM   #10 (permalink)
I see. It's like a u-pull-it in your own backyard. Not a bad idea.
Old 01-13-2007, 04:48 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You use the clip mainly for the engine and transmission. Everything (wiring, ecu, ignition system, etc...) is intact, which is not the case if you buy just an engine.
Clips are good for doing engine swaps. IE: 3S-FE to 3S-GTE.
http://toyotanation.com/forum/t135618.html
^ See thread for pics.
"Skoolin' the unlearned!"
Old 01-13-2007, 09:37 AM   #12 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
he has an alltrac guys, the camry alltrac trans is as strong as the regular fwd trans that comes in a camry, i think the turbo motor will trash it along with the rear drivetrain, would a v6 swap be a better choice?
Old 01-13-2007, 12:01 PM   #13 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
there was a guy in FL with an alltrac 3sgte swap... he's not on the board but i'll dig it up later tonight.... see if i can find a URL... i dunno what tranny he used.. may be st205 tranny ?
Old 01-13-2007, 07:05 PM   #14 (permalink)
white90dx's Avatar
The AWD auto may be suspect, but the AWD manual transmission is just fine. You'd want to replace it with the one from the donor Celica, but you can use all the stock Camry mounts (if its an AWD manual to start). The rear diff is a drop-in replacment and the axles are find for the power level, as you are splitting it between 4 wheels.
-Charlie
Old 01-15-2007, 07:21 PM   #15 (permalink)
89 camry dlx
ok im not sure what your talking about....ok i know what a clip is....now should i just plan on buying a car with a stick and just use my car as a clip or use my car and swap in a stick and if i do that do i have to change the rear and if i do what would need changed....and how hard is the wiring...i went to this web site it did help alittle but i need more help....and what rims are they on there i do like them
Need alittle help... 76CelicaGT Celica Forum 7 06-25-2006 08:56 PM
