Smelly heater core? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2007, 12:51 AM   #1 (permalink)
View 25psi's Photo Gallery
Smelly heater core?
I'm in southwestern FL so I don't use the heater all too often but when I do it puts off this very musty and thick smell, it doesn't "smell bad" per se but it's no fun breathing it. It's only when the heater core is being used, outside air or A/C is fine.
-Jim
91' Camry DX 3S-FE
25psi is offline   Reply With Quote
Old 01-13-2007, 01:09 AM   #2 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Find a shop that does a lot of AC work, which should not be difficult in Florida. Many shops are equipped to apply a spray bacteriostat and fungicide to the evaporator to prevent odors, and there is no reason those chemicals could not be applied to the heater core, as well.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-13-2007, 04:15 PM   #3 (permalink)
View toyomoho's Photo Gallery
You could have had moisture buildup and then mold over the years. Make sure the A/C evaporator drain tube is unplugged. This tube drains any condensation from A/C usage.
Rattling noise from my heater core on my 02 Camry kalinaprobe 5th & 6th Generation (2002-2006 & 2007-2011) 0 01-02-2007 01:52 PM
Is the a heater core problem? edwardr 1st & 2nd Generation (1983–1986 & 1987-1991) 4 10-23-2006 08:06 AM
heater core sureshot 89-95 Toyota Pickup/Hilux 2 10-12-2006 07:09 AM
Cleaning Heater Core silvers000 89-95 Toyota Pickup/Hilux 14 10-05-2006 11:35 PM
Need to get heater core out Ferrat Camry & Solara Lounge 3 06-13-2006 08:02 PM
