88 camry 4cyl auto wont start... HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2007, 12:24 AM   #1 (permalink)
View boi_si's Photo Gallery
my parents car will not start. i have a running 89 camry 5spd. we swap distributor and ignitor. fuel pump and fuel filter was replace with toyota parts about a yr ago. still no start. it cranks but no fire. timing belt looks fine. checked all fuses. seems like no check engine light is lighted. even with the diagnose terminal shorted.
possible ecu? any other i might need to check?
-03 Matrix XR
-90 Celica turbo Alltrac
boi_si is offline   Reply With Quote
Old 01-14-2007, 12:52 AM   #2 (permalink)
View toyomoho's Photo Gallery
The ECM may not be setup to store codes on this type of no start condition. A typical problem is the coil, but download the service info at the link below. Toyota has a diagnostics procedure for these types of no start conditions.
http://oregonstate.edu/~tongt/camry
Old 01-14-2007, 01:09 AM   #3 (permalink)
View QuietRonin's Photo Gallery
I had a similiar problem in my '90 5-speed and it turned out to be a bad EFI relay...though my problem only occured in the heat.
QuietRonin is offline   Reply With Quote
Old 01-14-2007, 01:33 PM   #4 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
I take the words "no fire" to mean that it will not run, but only cranks.
Have you done a check for spark at any of the spark plug wires, using a tester or old plug grounded to the block?
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-14-2007, 06:03 PM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Is Check engine light on steady with key in on position?
Doctor J is offline   Reply With Quote
Old 01-14-2007, 06:17 PM   #6 (permalink)
we swap whole distributor with my camry. spark plugs look fine. EFI relay has jus been swap with mine. still no start.
doctor J: no, check engine is not on. even with diagnose terminal short.
jus swap ecu with my 5spd ecu and still no start. very very clueless...
-03 Matrix XR
Old 01-14-2007, 07:40 PM   #7 (permalink)
The first clue is whether or not you have spark on the end of a plug wire, using a tester or an old plug, grounded to the block.
Old 01-15-2007, 03:39 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Back to Dr. J's question. With the key in accessory positionm, before you crank the engine, the idiot lights all go on to let you know that they are working. At this point, is the check engine light on or off?
I too, would like to know if you have spark at the plugs.
Kep
Old 01-15-2007, 08:55 PM   #9 (permalink)
Kep
with key on ACC, without cranking... theres no CEL light. others are lit on in ON position. doesnt seem like i have any spark at the end of spark plug wire.
whats next?
-03 Matrix XR
Old 01-16-2007, 05:51 AM   #10 (permalink)
Go to the online manual and lookup the diag for the CEL.
Old 01-16-2007, 08:06 AM   #11 (permalink)
Doctor J's Avatar
Check plug in connectors on ECU. Make sure they are pushed in.
Next, verify that there is 12 V on the wht/red tracer wires
at all times.
If so, unplug the connectors and check the input/ output circuits using link in Timebuilder's post.
Keep us posted.
Old 01-17-2007, 08:31 PM   #12 (permalink)
at all times.
Keep us posted.
i have the haynes manual in front of me.. wht/red wires give me a +b and +b1 as well as IGF. are those suppose to be 12v constant?
-03 Matrix XR
Old 01-18-2007, 08:01 AM   #13 (permalink)
Doctor J's Avatar
Only B+ and B1+ must be 12 V.
Old 01-18-2007, 12:29 PM   #14 (permalink)
Kep
Kep's Avatar
This is copied from "Tech Tip Corner"
Relay Runaround on Toyota Models
A faulty main circuit opening relay may cause an intermittent no-start condition on several Toyota models. If you are lucky enough to get the vehicle from the customer when it won't start, try this simple check before you waste any time on complicated diagnosis:
  • Turn the ignition to the ON position. The CHECK ENGINE light should be ON.
  • If the CHECK ENGINE light is not ON, locate the main circuit opening relay, then make sure you have more than nine volts on the output pole of the relay with the ignition in the ON position.
  • If the output voltage is below nine volts, but the input voltage to the relay is equal to battery voltage, replace the circuit opening relay. Its internal contacts are probably pitted and arced, which creates a voltage drop inside the relay.
I've spent more than one day on more than one car, trying to find an intermittent relay. Now I check the CHECK ENGINE light before I do any further diagnosis.
Brad Foltz
Miller Auto Group
Hedgeville, West Virginia
I am pretty sure that he is referring to the EFI relay. Since you swapped yours I am perplexed but still if your CEL isn't on when you put the key in accessory position it is awful suspicious. You may want to focus on the EFI wiring and the like.
Kep
Old 01-18-2007, 12:46 PM   #15 (permalink)
View OBwan's Photo Gallery
Fuel Pump....
OBwan is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
2007 Hybrid Camry In-depth Consumer Review phenderson Camry Hybrid 3 08-15-2006 06:57 PM
Valve adjust 1999 4cyl. Camry joede 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-14-2006 10:28 PM
Camry 2007 2.4L w/Manual transmission : Tough to start vinniemak 5th & 6th Generation (2002-2006 & 2007-2011) 4 07-07-2006 07:22 PM
Overheating (again) + sputter start = end of Camry? Redline Camry & Solara Lounge 6 04-20-2005 11:51 PM
