ALL that work and nothing changed!! PISS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 11:41 PM   #1 (permalink)
View MattSWE's Photo Gallery
2nd Generation ALL that work and nothing changed!! PISS
hey guys
Me and a friend took off and cleaned the egr valve and tube (totally clogged)
throttle body
ISC valve
coldstart injector
and the car still has a reving idle and sputtering on startup plus white smoke
I guess the ISC valve is shot, off to buy a new one. If that doesn't fix it...im not spending
another dime on the car
when I paid 65.00 to have it diagnosed, he said I need a new ISC and the air flow meter
was off on two pins when checked with an ohmmeter. new AFM maybe?
thanks guys for your help thus far.
MattSWE is offline   Reply With Quote
Old 01-16-2007, 05:49 AM   #2 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
I'd try to get both parts from a yard.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-16-2007, 11:47 AM   #3 (permalink)
Iac
now can I use a IAC valve from automatic AND manual cars or only manual with 2.0?
also, what years can I use them from? I have an 1991 DX 2.0, could I use one from an 88,89 or 90 4cyl
thanks man
Old 01-16-2007, 04:47 PM   #4 (permalink)
View toyomoho's Photo Gallery
Check an online store such as www.rockauto.com. See if the part numbers you are looking at match up.
Old 01-16-2007, 05:29 PM   #5 (permalink)
NYR
View IvanHoe's Photo Gallery
thanks man
It depends on 3 things
1)auto or manual?
2)was your car manufactured before or after 3/88(Im pretty sure the changeover occurred in March, but I would double check just to be sure)?
3)is it a 4cyl. or 6 cyl.?
They are pretty expensive, so I hope that your sure that the ISC is the problem
Why not take the car to a diagnostic place and see what they think?
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 01-16-2007, 06:00 PM   #6 (permalink)
I think that's the answer.
Old 01-16-2007, 07:08 PM   #7 (permalink)
NYR
Right, I read through the thread so fast that I mustve missed it..
I hope the the diagnostic guy is right then, cause an ISC is an expensive part....not to mention the air flow meter!
Old 01-16-2007, 07:12 PM   #8 (permalink)
No kidding! Maybe he should find out if that's a "guaranteed diagnosis," or perhaps he should seek a second opinion.
Old 01-16-2007, 07:18 PM   #9 (permalink)
NYR
+1!
Old 01-16-2007, 09:41 PM   #10 (permalink)
Iac
take it to toyota perhaps?
how much $$ would that cost
btw the mechanic did indeed diagnose the problem, its a shop that caters to japanese cars too. When I cleaned the IAC, I cleaned all the passages on it, but didn't touch the electrical part , should I have cleaned that too some how?
Old 01-17-2007, 02:30 AM   #11 (permalink)
I'd say no. From what I have seen of IAC's (a whole bunch from a host of companies) they have nothing inside to be cleaned or adjusted. Most have a stepper motor sealed inside using small, non-serviceable parts. The external part on most units, the pintle or valve assembly, is the part that gets dirty. Once that area and the associated passageways are cleaned, you have done your due diligence and it's time to replace a non-functioning unit.
As for cost, the IAC on my 1984 Supra 5M-GE engine cost $325 in 1986 when it failed at only 37,000 miles. In year 2006 dollars, that's $597.51.
Try yard parts, because used parts will reduce regret if the engine continues to behave the same way as before the repair. I have to say that because I don't know the basis of the diag results. Your chances are good if that shop is a Japanese specialty garage.
Old 01-17-2007, 03:39 AM   #12 (permalink)
NYR
I once read a thread on here of a guy with a MR2 n/a that actually took his ISC/IAC apart and cleaned it, then put it back together with succesfull results. He wrote that theres these little bearings inside that need to be lubricated as the final step before putting it pack together. You might want to try it since your gonna replace it anyways......who knows
Old 01-18-2007, 04:44 PM   #13 (permalink)
2nd Generation Iac
I have the standard 3S-FE 2.0 motor
5-speed manual transmission
1991 DX Sedan
what years of the camry's can I use (87-91) can I use them all as long as the car is a manual?
I just need the IAC btw
thanks guys
Old 01-18-2007, 04:51 PM   #14 (permalink)
NYR
1991 DX Sedan
thanks guys
I believe I already answered this earlier in the thread
.....but in case you missed it, I'll quote myself
1)auto or manual?
Old 01-19-2007, 11:53 AM   #15 (permalink)
ok thx
sry I thought that was a question
so I can use a IAC from 88-90-91
manual
2.0
now I know those are my guidelines
thanks a bunch, you guys have been very helpfull
btw how is your camry running IVAN?
