Crap!! >< new problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2007, 06:26 PM   #1 (permalink)
View monito's Photo Gallery
2nd Generation Crap!! >< new problem
OK.
i changed out the bulbs on my instrument cluster b/c one of them was burned out.
Now the turn signals don't work. the Emergency lights flash. but the turn signals don't. i took the cluster out again to see if i disconnected something, but everything seems to be ok, and all the lights seem to contact the board.
any thoughts?
I'd like to get this resolved ASAP, b/c i don't want to be the @$$hole that cuts people off w/ out signaling. Especially at night
monito is offline   Reply With Quote
Old 01-22-2007, 07:43 PM   #2 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
You may have blown a fuse. Check them.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 01-22-2007, 08:33 PM   #3 (permalink)
*edit: nevermind: i found it in the online manual *
where's te fuse for the turn signals located?
Old 01-22-2007, 09:00 PM   #4 (permalink)
fuse is ok both visibly and w/ ohmmeter
Old 01-23-2007, 12:21 AM   #5 (permalink)
Problem solved.
Really odd too. after i got back from the dealer, i decided to swap out the bulb from the 'PWR' indicator to the 'O/D' indicator, and i put the burned O/D bulb to where the PWR bulb was.
after re-assembling the cluster panel, and the switches, to my surprise, the turn signal worked again o.O
so... apparently, having one of the gear select guage bulbs off board breaks the circuit to the turn signal switch?!? weird o.O
Old 01-23-2007, 02:05 AM   #6 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
there ya go.
dont complain about toyota electrical until youve expereinced VW electrical - why use motors when you can use vacuum actuators?
anyways, good job...now go to the junk yard and pocket a few bulbs to replace the burned out ones.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 04:02 PM
99' Camry Start then dies Problem EBMCS03 Camry & Solara Lounge 6 08-30-2004 09:57 AM
Motor Mount problem and other, please help lazycat Camry & Solara Lounge 4 08-16-2004 09:32 PM
