1991 Camry Transmission or Electrical? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2007, 10:15 PM   #1 (permalink)
View John Martens's Photo Gallery
2nd Generation 1991 Camry Transmission or Electrical?
My father has a 1991 4 cyl Camry A/T with 255,000 km on it.
Today he stopped at the stoplight and when he went to accelerate, the engine would just rev like you have it in neutral, no forward motion. He turned off the ignition, turned it back on again within five seconds, put it in drive and drove away with no problems. Same thing happened every time he stopped the car at a light or in traffic. No odd noises heard, O/D light did not light up. Haven't had chance yet to pull codes. I haven't seen this anywhere else on the board. Suggestions?
John
John Martens is offline   Reply With Quote
Old 01-29-2007, 10:19 PM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
couldnt tell ya what the problem is, but the transmission is electronically controlled.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 01-29-2007, 10:31 PM   #3 (permalink)
View toyomoho's Photo Gallery
I think the ECM controls the shifting points and O/D engagement. Not the R or D engagement. Next time it happens see if the problem is in all forward gears and reverse.
Might be a manual shift valve. The link below provides access to the service manual. There is a good section on transmission diagnoses.
http://oregonstate.edu/~tongt/camry
Old 01-29-2007, 11:01 PM   #4 (permalink)
He says it has no motion in any gear until he shuts it off and restarts it. Then it will be ok until the vehicle comes to a stop again. I've got the entire repair manual saved on a CD so I'll start going through the troubleshooting guide.
Thanks
Old 01-30-2007, 12:04 AM   #5 (permalink)
View Kingdom934's Photo Gallery
Try check the fuse box inside the car (driver kick panel) to see if anything is blown.
I have tranny issues with a '85 Camry, seems to be a electrical issue as it keeps blowing out the ECT-IG. Lots of reving and little go in any gear except 'L' and 'R' from a stop position.
Kingdom934 is offline   Reply With Quote
Old 01-30-2007, 09:14 AM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The described defect is of mechanical nature.
The proper way to check it is to hook up the pressure gage to the transmission and check for line pressure. The home remedy is to clean the screen, but the problem is believed to be related to the to the worn sealing rings on the transmission front pump or stuck open pressure control valve.
Is fluid aerated (has bubbles of air in it)?
The dirty screen is usually causing slippage and judder at take off cold which improves as a line pressure builds up.
But drop the pan and clean the screen first. Let me know if there any metal is in the pan.
Doctor J is offline   Reply With Quote
Old 02-01-2007, 12:38 AM   #7 (permalink)
Checked the codes from the transmission, got no errors.Drove it around for a bit, and only after the engine was warm the problems began to manifest....you'd be driving, and then suddenly hear the engine racing because it wasn't transferring the power to the wheels. Pull over and turn it off..restart it and then it would be good for a mile or so.Checked the dipstick, and the fluid IS darker and does smell burned. I'd love to drop the pan and check for metal shavings, but dad says he'll just tow the car to a transmission shop on Monday...I'll go with him and give you all a update then.Thanks for the help.
Old 02-01-2007, 01:16 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Ohhh, I see dollar signs. If they suggest that the transmission needs to be rebuilt (which they always seem to do) I would definitely get some estimates on replacing the transmission instead. I am not a fan of rebuilt transmissions. Too much chance for human error. Even a used one might be better than rebuilding this one.
Just out of curiosity, how often has he changed the transmission fluid?
With the transmission failing as it is, you might want to consider a power flush. I hardly ever recommend them but if he is willing to replace/rebuild the transmission anyway it won't be a loss if it doesn't work and it might just clean out some crud that is blocking an important passage.
You might also start researching the various additives. If the service cost is more than he wants to pay there are all sorts of additives out there. They make outlandish claims but you may find one that helps his situation. Again, these are kind of last resort attempts. If they don't work or if they make the problem worse it doesn't matter because you were going to park the car or replace the tranny anyway.
Luck,
Kep
Old 02-01-2007, 02:46 PM   #9 (permalink)
Doctor J's Avatar
Trans-X was the good additive. If the hard (metal) parts are worn or damaged, it is less expensive to install used japanese transmission.
Old 02-01-2007, 04:51 PM   #10 (permalink)
Again I would down load the transmission service info and do some roads testing. The service manual has a lot of good info. The trans has about 4 electric solenoids that control shifting and OD on/off, plus a few other hydraulic valves. Most of these can be accessed without pulling out the trans. Could be just a sticking valve.
Old 02-01-2007, 06:44 PM   #11 (permalink)
Doctor J's Avatar
A140e transaxle has 2 shift and one lock up solenoid. Sticking valve will cause non-shift condition. The loss of line pressure causes tranny to fall out of gear.
Old 02-02-2007, 09:43 AM   #12 (permalink)
Toyota Veteran
View ironpig's Photo Gallery
It definitely sounds like a shift solenoid. They are fairly easy to replace just a little spendy.
1990 Hilux Surf 1988 Camry SE-X
ironpig is offline   Reply With Quote
Old 02-02-2007, 10:45 AM   #13 (permalink)
Doctor J's Avatar
When shift solenoid is plugged, the transmission will lose two gears, but the car will move.
The forward, reverse and low are controlled by manual valve.
Old 02-03-2007, 08:29 PM   #14 (permalink)
Transmission Update
Ok...
Pulled the tranny pan today...minor metal flakes, some metal 'flour' stuck to magnets.
Replaced the filter while I was in there..
Reinstalled the pan, dropped the car down, and put 2.5 litres of ATF in the filler tube. (as per repair manual)
Started it up, ran it through the gears and checked it again while it was idling. Mark came just below cold. Added a little more ATF.
Drove it around. Works great in all forward gears, but reverse had no guts. Would drop into reverse no problems but would hardly move at all with revving of engine. Added a bit more ATF. Drove around again. Now better speed in reverse. But now has odd 'scraping/grinding' sound coming from tranny. But only in reverse. All other gears it is silent.
Old 02-04-2007, 02:25 AM   #15 (permalink)
Tommy's Avatar
reverse and the forward gears are usually the first to go - time to start transmission shopping, it doesnt get any better from here out.
My garage
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
1991 camry needs help 1991_camry 1st & 2nd Generation (1983–1986 & 1987-1991) 1 09-22-2005 11:38 PM
1991 Camry Wagon Transmission medicpg Hardcore Tech and Competition 3 03-07-2005 09:51 AM
