1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
90 Camry Blower has a slide switch to adjust fan speed. I never had the lowest speed and I just lost the next speed up. I pulled the glove box and I think I found the resistor or relay, but I am not sure if there's a difference between a resistor or relay. After looking at ebay, I found a part that looked identical to the part i found, but it was called a relay. I also found a resistor part on ebay, which looks different. Fan still works in highest 2 speeds. Please advise.
those things are always breaking... resistors are the coils.. relay is just all covered you can't see anything...try pulling a few at the junk yard.. my lowest isn't working either
Yup, your resistors are gone. The resistor block is (as atobe said) the one with the little soldered coils on it; it unscrews from the firewall with one screw.
They're rediculously expensive ($65 at Toyota, last time I was stupid enough to even bother asking), so try a scrap yard. I've got three spares now since they go so often ($2 each at the wrecker's--free for lucky employees like me!).
I have never had a relay go in any of my Yotas. You can see that the resistor is gone by a gap in one or more of the coils. Repair is unfortunately hopeless.
__________________ 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
You can find others if you spend a few days monitoring, or you can contact the seller and see if he has one for the manual lever version.
Just a note, I have had my 1989 Camry for well over 100k miles and I have never replaced my resistor array. I did buy a used blower motor on ebay for less than $35 USD when my motor finally stopped turning, and I discovered that I had only been experiencing about 60% of what the "new" fan produced for output.
Just get a used resistor block and you're off and running.
I've had the same problem on my '87 a couple of times. I used to collect the resistor blocks and have a box full of them. To repair it, I find one that is similiar in # of windings and wire guage, solder on the coil and I'm good to go.
when i bought my '90 i had very little airflow. i got bored and aggrivated one day in the dead of winter and i pulled the glove box apart and discovered about 5 pounds of insulation inside the blower wheel, damn mice! because of that i dont have low.
I pulled twenty (yes, 20) spruce cones out of my friend's Bonneville's air intake. The had been stashed in the air cleaner box by a squirrel, and the sap had almost completely covered the filter element. Unbelieveable what you can find!
