then a trouble shooter. I'm getting diagnostic code 32 which means E2 open circuit or VC/VS short circuit. Went back to the factory manual and re read the FI diagnostic pages. Checked the air flow meter itself again. E2 to VC was 280ohm and in spec. I was using the wrong pin the last time
E2 to VS was 780ohm with the metal gate closed also in spec.
With the key ON at the AFM connector, disconnected from the AFM, I have 4.95V on the VC pin and only 1.5V at the VS pin. Spec for VS is 4-5V. I'm losing voltage somewhere along the way.
I'll check the electrical diagrams in the manual to see if there is any connectors along the way to the AFM connector to make sure they are tight.
I also need to check the E2/VC/VS pins at the ECU. Is the ECU in the glove box?
I wanted to ask the fine folks here if I'm on the right track. I'm really
when it comes to this electrical troubleshooting.
Thanks
Brian
