Need help in removing Oil Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2007, 03:12 PM   #1 (permalink)
View catsgrave's Photo Gallery
Australia Need help in removing Oil Filter
Hi guys,
I just acquired a used 91 Camry 3SFE about a mnth ago
I want to change my oil filter. It has not been changed since 2001 ! I bought all the necessary tools. But i still cant get the damn thing out. Its too tight.
I have a oil filter remover ( its like a clamp with 3 claws) but the damn thing slips when i try to use a 3/8 " drive
Any suggestions?
I am such an absolute newbie and idiot. I bought about more than $100 worth of parts and tools and it seems useless. arrghh
thanks
catsgrave is offline   Reply With Quote
Old 02-25-2007, 03:18 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
2 things you can get, the cup that fits the end or the 2 grip type, they also make a bar that fits on a ratchet with a piece of a seat belt on it that will take anything off
Old 02-25-2007, 04:04 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
worst case stab it with a screw driver sideways and turn it
Old 02-25-2007, 06:09 PM   #4 (permalink)
aussie_gen1's Avatar
View aussie_gen1's Photo Gallery
are you turning it the right way? try anti-clockwise
aussie_gen1 is offline   Reply With Quote
Old 02-25-2007, 06:12 PM   #5 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
My experience with stabbing a filter is it tears the filter and makes a mess and doesn't necessairly come off. Use a Filter socket-- 5-10usd.
66conv6 is offline   Reply With Quote
Old 02-26-2007, 01:22 AM   #6 (permalink)
Australia
thanks for the reply guys,
I bought 2 types of filter removal.. n i still cant get it done. i am bringin my car to the mechanics and get them to do a major service. I might get 1 of them to show me how to get that bloody thing out.
Old 02-26-2007, 03:55 AM   #7 (permalink)
View monito's Photo Gallery
by one of those cheap oil filter wrench bands
bond it to the oil filter [glue, rubber cement etc]
and force it off... also try PB Blaster or similar pentetrant. it's possible the gasket's completely gone, and the metal filter bonded w/ the body.
monito is offline   Reply With Quote
Old 02-26-2007, 08:22 AM   #8 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Fredk mentioned the fix.
Find the "strap" type of filter wrench. Generally, it's a piece of square tube with a strong nylon strap captured in a groove on the side. The more you turn the square tube the tighter the strap becomes. I used to place an extra piece of metal under the area where the box channel presses against the side of the filter, to prevent the box from distorting the side of the filter. When the filter starts to "give" there, you are no longer exerting turning force.
Place the strap wrench as close to the bottom of the filter as possible, near to where the filter contacts the block. You want to be trying to turn the filter in the opposite direction of the hands of a clock, therefore the term "counterclockwise" or "anticlockwise."
I have removed the most difficult filters used on everything from Kawasaki lawn mower engines to tractor trailer engines (Caterpillar, Cummins, Detroit, International) by using the same strap wrench. I only bring it out for the bad ones.
If you properly install the new filter, the Toyota cup wrench will work fine from now on.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 02-26-2007, 08:55 AM   #9 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The strap and similar wrenches are difficult to use on 3SFE due to the limited space.
If filter is standard size use cup wrench. You may also slightly bump it in to make sure it seating tight on the filter.
Spray the area near the filter base with penetrating oil. After 30 minutes, start the engine and let it warm (1/4 scale on the gage), then shut it off .Proceed with filter removal.
Doctor J is offline   Reply With Quote
Old 02-26-2007, 11:55 AM   #10 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
In situations like this, it's usually the rubber seal that has absolutely bonded itself to the face that it seals against. The best-case senerio is that you can get it off with some type of wrench. If that doesn't work, you usually have to use a destructive method to remove it. 66conv6 is right, I've never had much luck with the screwdriver-stab method. The can material is usually too weak to allow any kind of torque to be applied to it, although it has worked once for me.
BTW: 2001 was the last filter change?? How many miles has it been?
Oh, and welcome to the forum!!
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 02-26-2007, 01:46 PM   #11 (permalink)
View car_boy_16's Photo Gallery
...time to get out the sawzall!! Tear that bastard up, then get a wrench and rip that damn filter off. Cap it off, refill oil, wash your hands, get a beer.... and you're
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 02-26-2007, 08:44 PM   #12 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
u betcha, that will make a big mess though, the strap will whoop its ass
Old 02-26-2007, 08:55 PM   #13 (permalink)
HomeGrown's Avatar
Nope. Drink a beer first, then open another beer and grab the strap wrench. Remove & replace filter, wash hands, drink remaining beer.
BTW: "... slower than a school bus" I like that. Sad, though...
Old 02-28-2007, 08:30 AM   #14 (permalink)
View ozzi's Photo Gallery
Git Mo Grip
Try using a piece of the urethane tool drawer liner that feels sticky.
Put around filter.
Use a belt or strap and go around the liner and filter and the end of a long socket extension placed down the side of the filter.
Wrap sos the strap chokes the filter in the undo direction when you tighten the strap with the extension.
Attach rachet to extension and hold strap as you twist.
ozzi
ozzi is offline   Reply With Quote
Sure was fun changing my oil today... Infinitrium Archived Corolla threads 18 10-12-2006 08:38 PM
Full synthetic motor oil - 32¢ /quart + 1 oil filter ... Pep Boys skewe General Discussion 7 01-19-2006 03:31 PM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 04:32 AM
What I found when changing the oil. Kooter Camry & Solara Lounge 2 10-19-2003 06:37 PM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 10:01 PM
