Brake light relay? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2007, 11:33 AM   #1 (permalink)
Blazyntoyo
View 90camdx4's Photo Gallery
Canada Brake light relay?
Does anyone know which one of he relay control the brake lights?....i used the search and nothing was found, also my relays a the black plasctic ones...can i use the silver steel ones?
90camdx4 is offline   Reply With Quote
Old 02-28-2007, 04:16 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
What's happened to make you think the relay is gone? If you're getting the warning light coming on in the instrument cluster, replace the little yellow electrical box located behind the driver's side wheel well in the trunk. When they malfunction the warning light will stay on, even if the lights are all good...
The taillight relay is under the dash near the driver's left foot. You'll probably have to remove the kick panel and trim to get at it.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-02-2007, 09:47 PM   #3 (permalink)
Blazyntoyo
the relay is good, also the lamp failure sensor(yellow box)...i have a short somewhere, i changed the two tail light assembly on the trunk lid...it worked fine for about 15 mins and the failure light was on again, no brake light on right trunk lid side.
got to find the problem.
Old 03-03-2007, 08:43 PM   #4 (permalink)
Bullitprooph
Try following the wiring along the inside of the trunk lid, and down to the main harness...often there's wear on them from stuff rubbing...
Old 03-05-2007, 03:37 PM   #5 (permalink)
Blazyntoyo
thanks i'll check that and see if i find any damaged wires.
do u still have access to that es250 u got your motor from? i want the strut tower bar from it, if its available, thanks
Old 03-05-2007, 08:46 PM   #6 (permalink)
Bullitprooph
I can go see them later this week when I have time, but they want $20 for it and it's got some rust patches on it (no rust holes though). You still want it if they've still got it?
Old 03-08-2007, 11:56 AM   #7 (permalink)
Blazyntoyo
yah i still want...but how am i gonna get it? shipping? oh by the way i found the wire that was giving me problems...it was one of the green ones on the passenger side assembly, all fixed now.
Old 03-08-2007, 02:17 PM   #8 (permalink)
Bullitprooph
I'm glad your problem is fixed...I had the same issue awhile back.
As for the strut brace, I can bring it down this summer when I visit my family (in Toronto). But I would need to know you'll want it so I'm not out the $20...
What do I have to do to get a left brake light on the trailer when towing??? Ron V 2nd Generation (2005+) 4 10-09-2006 05:50 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
1996 Corolla Third Brake Light BigTattoo Archived Corolla threads 6 10-23-2005 12:21 PM
Gen5 Brake Light VVT-i Owns 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-25-2004 05:01 PM
L.E.D. Tail/brake light & 3rd brake light conversion project eviltwin67 Camry & Solara Lounge 2 07-02-2003 10:24 AM
