Anyone have experience with increasing compression - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2007, 03:55 AM   #1 (permalink)
Insanity makes more sense
View WVcamry3sfe's Photo Gallery
I'm interested in increasing the compression on my 3sfe. does anyone have experience with this? Still in the research phase, but it seems like a fairly practical way to bolster engine power without messing with a turbo/forced induction.
WVcamry3sfe is offline   Reply With Quote
Old 02-28-2007, 04:56 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
3s-gte it
unless you have your own workshop that is... then i suppose you could mill the head a bit...
terrastrife is offline   Reply With Quote
Old 02-28-2007, 10:49 AM   #3 (permalink)
View Variety=Spice's Photo Gallery
some VW fanatics will use a thin metal head gasket instead of the thicker fiber gasket to reduce the cylinder volume, thus increasing compression.
You could weld the cup in the top of the piston full...the cup that prevents valves from getting bent when the timing belt blows.
Your best bet, if you're serious, is to have fresh piston rings and well seated valves in your beast to capitalize on the compression you do have.
How much variability do you have in compression between your cylinders currently?
Variety=Spice is offline   Reply With Quote
Old 02-28-2007, 07:08 PM   #4 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
there is a company that makes high comp pistons for the 3SFE, sure a google search or a TN search would pull it up.
you're not going to gain anything by doing it though, with high compression you need more fuel, more fuel needs more air and so on. by the time your done, youve spent more than its worth on the gains.
Just do a GTE or a GE swap
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 03-02-2007, 11:35 AM   #5 (permalink)
View dillspy's Photo Gallery
I'd prolly go with the gte conversion or the high compression pistons. When you mill an overhead cam engine, you have to start watching how it is going to effect the valvetrain. You could mill a little bit out to get some compression but if you go to far the timing could get messed up. Then if you get more compression, you might have to cam it to get the dynamic compression back down to 7-7.5. Depending on what fuel you are going to run. We are doing a 3sgte swap right now. Picked it up about 100 miles away. Hope this helps. I've also found a 2.2L stroker kit. But that is about $2300.
dillspy is offline   Reply With Quote
Old 04-02-2007, 12:47 PM   #6 (permalink)
View marc780's Photo Gallery
You can increase compression by the way they said, changing pistons and even boring out the engine if power is your goal. It increase strain on the valve train and crank and what you are really hinting at is a turbocharger installation which does exactly what you describe.
Old 04-02-2007, 04:51 PM   #7 (permalink)
View rustySFE's Photo Gallery
It would only be worth it if you did all of the work yourself.
IMO, I don't see why increasing compression would be a bad idea but just don't go overboard. I would stay away from removing layers on a multi-layer steel gasket.
The shop down the street from me does $50 mill and surfacing.
I took .030" and used a thinner HG on my CRX to go from stock 9.2:1 to right at 10:1.
Still run 87 and picked up 3ft-lbs peak on the dynojet but picked up 5-6ft-lbs everywhere under 4000.
I do have an adjustable cam gear however as the cam/cams will be slightly advanced or it could be retarded (cam gear is on drivers side on hondas).
In the name of the best within us
rustySFE is offline   Reply With Quote
Old 04-02-2007, 05:43 PM   #8 (permalink)
View car_boy_16's Photo Gallery
If you mill your head your timing will be off, so you'd need adjustable cam sprokets...I don't know if anybody makes them for the 3sfe, but you'd need them otherwise you're just creating more problems than you'd want.
You don't need to dump more fuel into your car if you increase your compression. All the increased compression does is squish the air:fuel mixture together into a tighter and more compact order. It makes for a quicker and more forceful explansion when ignited. Although, it will run hotter during the top of the compression stroke though so if premium fuel doesn't stop preignition then yes you would have to either back off the intake cam, or add more fuel, or both.
I wonder how much it would take before your milled head, and after you adjust the cam timing, turns the engine into an interference engine.
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 04-02-2007, 11:47 PM   #9 (permalink)
I think on the honda d motors (mine specifically a d15b2) .040" equated to 10 degrees advanced.
My adjustable cam gear is set at 8 degrees retarded as it produced the best curve for my desired peak HP RPM. One tooth = 10 degrees.
You should mill it .040-.050", retard the cam gears one tooth and let us know how it went.
It would probably be pretty easy, measure cranking compression before and see if its close after milling and moving the cam gears back a tooth.
Old 04-03-2007, 04:23 PM   #10 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I understand how milling the head could affect valve timing, but not to the extent that it would actually require correction. I did a rough layout on AutoCAD and found that lowering the head .040" would affect the the cam gear angle by only 0.02 degrees. This measurement was based on a 3" dia. gear, a smaller diameter gear size would increase the angular change. If I had the actual gear size I could do a more accurate analysis.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Increasing compression 94_Rolla_Guy Hardcore Tech and Competition 4 11-01-2006 12:39 AM
Surprisingly good compression!? NickR Tercel, Paseo, Starlet, and Sera Forum 3 06-27-2006 06:38 AM
MR2 vs. Integra mr2trd MR2 Forum 85 05-08-2005 04:51 AM
Toyota Compression Testing?? celica2004 Archived Corolla threads 1 03-28-2005 01:33 AM
What compression ratio to use? Gen3cruiser Camry & Solara Lounge 30 10-04-2004 11:27 PM
