Rack and pinion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2007, 08:38 PM   #1 (permalink)
dafugitive415's Avatar
View dafugitive415's Photo Gallery
2nd Generation Rack and pinion
What sup yo, I just replace the cv boots and the new axel. Now I found out my rack and pinion (the rubber part) is torn out. I was wondering is it important to replace it or just leave it?
dafugitive415 is offline   Reply With Quote
Old 03-03-2007, 01:16 AM   #2 (permalink)
View toyomoho's Photo Gallery
The purpose of the boots is to keep out road dirt, sand, etc from the rack and rack end(s). Over time this will wear out the seals, connecting rod joints, etc. If you do the job yourself replacing them is not too bad a job. Keep track of how many turns it takes remove the rod ends or where the nut is. Any thing to allow you to reinstall the rod ends in the same position.
Old 03-03-2007, 08:41 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Yup, otherwise you'll be paying $70 for an alignment you could've easily prevented.
Here's a tip: before you unthread the tierod end from the rack, mark it's location on the threads with paint. It'll make it easier to re-tighten to the right location.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Rack & pinion and 2 Axels Replaced! 73sport 3rd & 4th Generation (1992–1996 & 1997–2001) 16 07-18-2010 12:24 AM
Replace rack and pinion 1996 Avalon TMack409 1st Generation (1995-1999) 2 02-12-2007 03:34 PM
Stealership wants to replace rack & pinion - 2003 LE w/ 55K bcnland 5th & 6th Generation (2002-2006 & 2007-2011) 8 10-08-2005 09:37 AM
Rack and pinion replacement? rh8746 Celica Forum 4 08-15-2005 10:29 PM
89 Camry Rack and Pinion njc78750 1st & 2nd Generation (1983–1986 & 1987-1991) 3 02-16-2005 12:48 AM
