Oxygen Sensor - exists & how to change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2007, 11:45 AM   #1 (permalink)
View fix_wifes_camry's Photo Gallery
Gentlemen,
1990 Camry with 2-litre. In preparation for an upcoming emissions test, I was thinking of changing the oxygen sensor. But it'll help mileage too.
Question 1 - IS there one on these cars?
Question 2 - is there much more to it than simply finding the thing and unscrewing it from the exhaust pipe and screwing in new one?
Thanks.
fix_wifes_camry is offline   Reply With Quote
Old 03-06-2007, 01:11 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Assuming you have a non-CA model 4-cylinder, it is quite easy to change the O2 sensor. It is a Toyota specific part (not the standard screw-in type) that is held on by two nuts, on the exhaust manifold just above the catalytic converter... Hit it with some penitrating fluid to loosen the rust (PB Blaster or similar), wait a bit, and change it out.
There are many other things that could be causing poor fuel economy, so you should also check some other stuff out... (spark plugs, air filter, injectors, ignition system, plugged cat, worn out motor, etc)
-Charlie
Old 03-06-2007, 01:37 PM   #3 (permalink)
View monito's Photo Gallery
-Charlie
Yep!! it really is THAT simple! i just did this last week.
If you have mechanic's gloves, or gloves that can help you tolerate high temperatures, spray the penetrating fluid after it's been driven. once the engine cools down [1/2 hour to an hour] the nuts will come off easily.
and
Before fastening the new O2 sensor in, be sure to use some anti-seize on the bolt.
monito is offline   Reply With Quote
Old 03-06-2007, 02:11 PM   #4 (permalink)
Gameroom cash: $302555
What makes you think your car needs a new O2 sensor? Is the check engine light (also called the MIL light) on? When an O2 sensor goes out of range, it will set off the check engine light. You can change it out if you like, but if the light is not on, most likely it's not needed.
Mike
Old 03-06-2007, 06:43 PM   #5 (permalink)
OK, thanks all.
*DIY* Stock Stereo LED color change - (Lots of PICS) - 56k no way SnakeyeS Camry & Solara Lounge 56 12-09-2010 02:51 AM
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
'96 Avalon Timing Belt Change Advice Brown Bear 1st Generation (1995-1999) 1 09-06-2006 12:37 AM
How often do you change your engine oil? solidg Camry & Solara Lounge 88 01-11-2006 10:12 PM
About to change my oil on my new camry,what type oil to change it to?high mileage cam Whitecamryghost Camry & Solara Lounge 9 09-25-2005 11:36 PM
