water pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2007, 11:43 PM   #1 (permalink)
View GTO MAN's Photo Gallery
water pump
What do you think it should cost to replace on a 1990 4cy with air? Thanks.
GTO MAN is offline   Reply With Quote
Old 03-07-2007, 12:12 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Are you thinking of paying a mechanic, or do you want to do the work yourself? Because the water pump itself shouldn't be more than $30 (aftermarket) or $60 (Toyota part). But paying a pro to do it will be pricey...just getting at it is difficult...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-07-2007, 03:12 AM   #3 (permalink)
NYR
View IvanHoe's Photo Gallery
water pumps on these cars are not easy to replace by yourself
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 03-07-2007, 12:30 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
It will probably be a couple of hundred. It is in the same area as the timing belt. I believe that it is driven off of the timing belt but I am not sure of that. Usually, when you go in to do one you do the other in order to save going in again.
For some reason I understand that timing belts deteriorate if exposed to oil or water. If your water pump has been leaking it is quite possible that your belt has be affected. I would say if your belt is possibly damaged or has more than 40,000 miles on it you may want to go ahead and change it out while you have that area open. Also check the tensioner and seals while you're there.
Kep
Old 03-08-2007, 12:17 PM   #5 (permalink)
Blazyntoyo
View 90camdx4's Photo Gallery
I did my tbelt and pump along with tensioner,crankshaft seal...it ended up to be about $300.cdn in parts alone, i choose to go with parts from toyota, had aftermarket pump lasted about 50k. u should change all belts, if they havent been changed in a while.
if u intend to keep the car for another 60,000 miles i would suggest that u use oem toyota belt and pump etc.
90camdx4 is offline   Reply With Quote
Old 03-14-2007, 12:49 AM   #6 (permalink)
I need a bottom tensioner it can be a used one if it is ok, I need it asap, I do thank anyone for any help, THANKS randy.
Old 03-14-2007, 09:07 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
just get a belt kit, it will come with all the idlers
Old 03-14-2007, 10:31 PM   #8 (permalink)
Unhappy
Thanks for the reply, The kit is 80 bucks here I only need one part, Thanks for any help. randy.
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
2002 Camry Water Pump Weeping? Conan555 5th & 6th Generation (2002-2006 & 2007-2011) 5 03-06-2007 03:06 PM
Water Pump + etc. supercharger Archived Corolla threads 10 01-20-2007 02:34 AM
91 corolla water pump? tysn Archived Corolla threads 3 11-09-2006 06:41 AM
Recycling Water Pump??? Snip3r General Discussion 0 11-14-2005 03:40 AM
