gen2 auto 2 5-speed conversion help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2007, 10:41 AM   #1 (permalink)
Its A Camry Thing... ok?
View SymtecX2003's Photo Gallery
Exclamation gen2 auto 2 5-speed conversion help
Just Dont Feel Like Going Through The Trouble Of Changing To Another Automatic Trans Again, Alot Of Wrench Time To Get It To Line Up. So If Anyone Can Show Me Some Links Or Ect On Where To Get Started On My Manual Swap Please Do So, Btw My Swap Is Comming Out Of An 89 Gen 2 Camry Wagon
http://i11.photobucket.com/albums/a1...X/100_3144.jpg
It may be a camry but its mine....
SymtecX2003 is offline   Reply With Quote
Old 03-09-2007, 11:38 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
search for jetspeed's thread on his e153 swap
Old 03-09-2007, 01:28 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
If you have access to the complete MT car... you'll want the following stuff:
Pedals
Clutch master cylinder
Clutch slave cylinder
All clutch lines
Shifter base and cables
Shifter surround
Gauge cluster surround
ECU (the wiring other than the A/T wiring is the same as long as it comes from the same year car)
All three transmission mounts with brackets
Axles (your stock hubs are fine)
Correct flywheel for your motor (6 or 8 bolt)
New clutch and pressure plate
That should be about it... I'm sure I missed a few things in there though. I believe there is a small issue with wiring the "Park" switch and clutch switch that you might also have to figure out to get the car to start...
-Charlie
Old 03-09-2007, 04:04 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
he will need a car with a manual in it for everything that touches the trans but the axles, or he can make his own can of worms and put an e153 in it
Old 03-09-2007, 08:07 PM   #5 (permalink)
white90dx's Avatar
The E153 is not a huge can of worms... I have one in my car.
Of course, doing the standard 5-speed is plenty for a stock 3s-fe...
-Charlie
Old 03-09-2007, 08:21 PM   #6 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I just searched for jetspeed's swap thread but couldn't find it. That is probably the most informative thread I've seen on the subject.
EDIT: I found it. http://www.toyotanation.com/forum/t85352.html
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Scrapyard in the GTA TdotTercel General Discussion 16 11-23-2011 03:18 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
4 speed to 5 speed conversion diesel_fireman Pre-88 Toyota Pickup/Hilux 2 12-30-2005 08:43 PM
Auto to Manual Conversion aus_camry Camry & Solara Lounge 4 05-25-2005 06:33 AM
Standard To Manual 6 Speed Conversion vtsuckah Supra Forum 9 10-01-2004 07:34 AM
