This may be a dumb question, but... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2007, 04:01 PM   #1 (permalink)
View movement's Photo Gallery
2nd Generation This may be a dumb question, but...
How do you "pop" out the air registers on the 1990 camry? I already broke one. Also, how do you get the faceplate that surrounds the radio? Is there a screw inside the dash?
Thanks
Nick
movement is offline   Reply With Quote
Old 03-12-2007, 04:20 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
I don't know about the air vents, but...
You can remove the faceplate around the radio pretty easily. There are two screws at the top that must be removed, then from there you just pull straight out. The clips are in there pretty well, so it will take a good strong tug. Good luck (they do break if you do it wrong).
-Charlie
Old 03-13-2007, 12:34 AM   #3 (permalink)
View toyomoho's Photo Gallery
The faceplate comes out; it takes a little finesse to pry it. The link below provides access to service manuals.
http://oregonstate.edu/~tongt/camry
Old 03-13-2007, 11:28 AM   #4 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I removed one of my air vents so I could mount the Sirius receiver. I used a small screwdriver and pushed in at the pivot point on one side, pulled out slightly, then repeated on the other side of the vent.
The radio surround is a bit tricky. I've had mine on & off about a dozen times now, and those clips are still pretty strong. One set of clips is behind the cross-bar between the heater controls and the radio. The other set is at the bottom of the bezel.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Heres a dumb 4wd question pee_cup 89-95 Toyota Pickup/Hilux 3 12-12-2006 03:19 PM
DUMB question sorry but have to ask. NH05TACOMA 2nd Generation (2005+) 20 01-19-2006 11:50 AM
Kinda a Dumb Question... Lauren Off Topic 97 02-25-2005 06:53 PM
stupid, dumb, retarded cardomain question? felkajamine Off Topic 7 01-13-2005 07:06 PM
Dumb question VVT-i Owns Off Topic 1 07-21-2003 11:41 PM
