AC Idle-up
Hello, I've owned a '94 Corolla and a '89 Celica for quite a while, and just recently added a '90 Camry. The Camry is a 4-cyl auto. This problem is shared by the '89 Celica.
The engine does not seem to be able to idle up for the AC, causing the AC to kick off when sitting. I've been told that this is most likely the VSV valve. I called the dealership, and he found the Idle Up Actuator for $48. Does this sound like the correct part to fix the problem? The part is the same between the Celica and the Camry...
I'm strongly against picketing, but I'm not sure how to show it...
