'90 Camry Blinker - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2007, 03:05 PM   #1 (permalink)
View wiccanferret's Photo Gallery
'90 Camry Blinker
When you turn the blinker to the right, it's good. When you turn it to the left, it makes a staticy buzzing noise unless you nudge it just a bit up. The hazards work fine with no noise. I'm assuming the handle/switch needs to be replaced. Does that sound accurate?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 03-15-2007, 04:20 PM   #2 (permalink)
View toyomoho's Photo Gallery
The electrical contacts in the switch may just need cleaning. Or perhaps a little lubricant on the arm mechanism.
Old 03-15-2007, 05:39 PM   #3 (permalink)
View nogard's Photo Gallery
I would agree, I had this problem once. Took the assembly apart and cleaned with contact cleaner. The parts the slide against each other when the turn signal wand is moved slightly arc (electrically) when this is done enough it builds up carbon deposits, over time snow balling the effect.
nogard is offline   Reply With Quote
Old 03-16-2007, 11:51 AM   #4 (permalink)
Do you have to remove the steering wheel to remove the combo switch? Maybe I should just spray some electrical component cleaner in there before I start disassembling?
Old 03-16-2007, 11:50 PM   #5 (permalink)
NYR
View IvanHoe's Photo Gallery
The switch is on the way out inside the column....it's a common issue
BTW, I found out about it myself a month ago by using the search option.....I hear it works pretty good
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
90 Camry Window Relay Location wallsauce 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-17-2005 12:32 PM
90 Camry hard to start hwy101 1st & 2nd Generation (1983–1986 & 1987-1991) 2 11-13-2005 11:02 AM
90 Camry: problems re-starting in cold weather catfisher 1st & 2nd Generation (1983–1986 & 1987-1991) 5 11-06-2005 10:31 PM
90 Camry Auto - no reverse greenskeeper 1st & 2nd Generation (1983–1986 & 1987-1991) 3 02-02-2005 12:27 AM
90 camry warning lights stay on 90camry 1st & 2nd Generation (1983–1986 & 1987-1991) 1 09-23-2003 08:20 PM
