91 Camry Fan problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2007, 01:43 AM   #1 (permalink)
View bigbikes2003's Photo Gallery
Australia 91 Camry Fan problems
Hi Guys. Just wondering if someone can give me a bit of advice on my daughters car. It a 1991 2 ltr Camery (second gen I thik)
As she has not long had her licence I thought it would be a good first car for her, which it has been so far, What I have noticed though is that when ever you turn the key on, the cooling fan comes on immediatly, no matter if its first thing in the morning (when its cold) or any other time.
My question is, should it turn itself on as soon as the ignition is on? or should it wait till the car warms up a bit?
Is there a way to adjust when it switches on?
As Im not a mechanic I thought I'd leave it up to the people that know....You guys
Thanks again guys
Cheers all
Peter
bigbikes2003 is offline   Reply With Quote
Old 03-19-2007, 01:56 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Hey,
Open up the fuse cover in the engine bay (near the battery) and tap the relays.
If that doesnt fix it, grab another one from a wreckers. (The relays for there application are marked on the fuse cover). You'll be after the ones that refer to "FAN".
Its just sometimes they get sticky.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 03-19-2007, 02:53 AM   #3 (permalink)
Thanks for that Jetspeed.I'll do that as soon as she gets home from work tonight.
But tell me, at what temp should it actually start up?
Cheers
Old 03-19-2007, 04:07 AM   #4 (permalink)
VeeZed
Mine usually kicks in at around 90 degree coolant temprature..and shuts back off at about 88 degrees. On a cool day/night, they never turn on!
Old 03-19-2007, 06:53 AM   #5 (permalink)
Hi Jetspeed.
Have taken all fuses out and replaced them, but the dam fans still stay on all the time.
Any other suggestions?
cheers
Old 03-19-2007, 02:42 PM   #6 (permalink)
Gameroom cash: $302555
He was talking about the relay marked "fan", not the fuses. The relays are much bigger in size than the fuses. I think he might be correct, the relay may be stuck on so that the fan(s) are running all the time.
Mike
Old 03-20-2007, 12:50 AM   #7 (permalink)
Hi Mike
That was my mistake. I meant to say replaced the relays (not the fuses) sorry about that, but still I have the same problem.
Both fans are staying on
Any other suggestions at all what I should check.
Cheers
Old 03-20-2007, 04:52 AM   #8 (permalink)
curtisz's Avatar
Gameroom cash: $113910
View curtisz's Photo Gallery
I would check to see if the previous owner might have circumvented the relay and hard wired it to be constantly on. That was the case in an older Corolla I used to own.
curtisz is offline   Reply With Quote
Old 03-20-2007, 04:02 PM   #9 (permalink)
View Variety=Spice's Photo Gallery
actually, on the 91 Camry there is a relay under the inside passenger side knee bolster that will fail in the closed position and make the fans run whenever the key is on. I had the same problem and replacing that relay fixed it. There are a few threads on the topic.
I have an extra one I'd part with for the price of a good six-pack plus shipping.
Edit to add link: Solved. Both Fans Run High Speed All the Time
Variety=Spice is offline   Reply With Quote
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
2007 Camry Seat Belt Trunk Sunroof Problems. Rotten Eggs grosenbeck 5th & 6th Generation (2002-2006 & 2007-2011) 4 04-19-2006 10:17 PM
Who has had transmission problems in a Gen 3 Camry? JSVH 3rd & 4th Generation (1992–1996 & 1997–2001) 51 12-30-2004 03:44 PM
91 Camry charging problems? Dave M 1st & 2nd Generation (1983–1986 & 1987-1991) 3 07-21-2004 12:53 AM
