91 now ALWAYS idles at 1500rpm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2007, 02:22 AM   #1 (permalink)
View MattSWE's Photo Gallery
2nd Generation 91 now ALWAYS idles at 1500rpm
the idle never goes down now and when I step on the gas, it stalls badly. It definetely smells like its running rich since after it sits for a few hours it sputters and dies like a bitch. I replaced my ISC, cold start injector, no vaccum leaks, cleaned out EGR valve. New plugs, wires cap and rotor button.
I guess its on to the coolant temp sensor and AFM.
can anybody post up a pic of the coolant temp sensor please.
thanks guys
MattSWE is offline   Reply With Quote
Old 03-22-2007, 04:19 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
dont have a pic, but the only one of any concern is atop the thermostat housing, its the one with the big rubber boot covering it i believe.
grab your haynes and do the test for the afm, does sound like a possibility.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 03-22-2007, 07:53 AM   #3 (permalink)
Toyota Veteran
View ironpig's Photo Gallery
did you replace the cold start injector or clean it? try unplugging the connector and start it up.
1990 Hilux Surf 1988 Camry SE-X
ironpig is offline   Reply With Quote
Old 03-22-2007, 11:56 AM   #4 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
A bad CSI will leak when unplugged, it just won't have the start-up spray. Mine was bad, but didn't cause fast idle, only difficult starting after sitting a few hours, from the constant drip of gas into the intake.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 03-22-2007, 12:10 PM   #5 (permalink)
View toyomoho's Photo Gallery
Download the Gen_2 EFI Section from the link below. Has a very good troubleshooting section with methods to test the components.
http://oregonstate.edu/~tongt/camry
Old 03-22-2007, 01:01 PM   #6 (permalink)
Ancientwolf13's Avatar
View Ancientwolf13's Photo Gallery
One reason could be your throttle positioning sensor not reacting properly. Check it to see if it is dirty or corroding.
Ancientwolf13 is offline   Reply With Quote
Old 03-22-2007, 01:35 PM   #7 (permalink)
2nd Generation thanks guys
the throttle position sensor is that black box behind the TB right. I'll test the afm again too. I'll take apart the TPS and clean it i guess
Old 03-22-2007, 08:52 PM   #8 (permalink)
View nuron's Photo Gallery
HomeGrown, what do you mean when it will leak when unplugged? From the gasket or the nozzle itself? I think I might have a bad CSI so when I took it out and cranked the engine, I was looking for a spray but didn't see anything.
nuron is offline   Reply With Quote
Old 03-25-2007, 01:27 AM   #9 (permalink)
Tested the CSI and resistance seems normal. I got a CSI time switch from a yard and the plugs are different . Mines are rectangular and the one from the yard is rounder. Hope the splicing works.
Old 03-25-2007, 03:36 AM   #10 (permalink)
well, today I unplugged my CSI and it helped my problem, it doesn't sputter on startup and idles down a lot lot quicker, and stays around a normal idle. I'll replace my CTS and see if that does anything
i guess driving without the CSI plugged in is alright
Old 03-28-2007, 10:43 PM   #11 (permalink)
could the timing or plugs/wires be my problem, the new coolant temp sensor with the metal prong underneath the housing didn't do anything at all. Maybe my AFM or computer? Im just tired of stepping on the gas or shifting and the car jerking badly like its stalling severly.
FS: 91 5sfe parts (cheap) mr2trd91 Car Parts for Sale 2 09-04-2007 01:52 AM
94 4afe into 91 Corolla fabbb Archived Corolla threads 4 12-11-2006 08:19 PM
