Trim - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2007, 06:39 PM   #1 (permalink)
View wiccanferret's Photo Gallery
Trim
The black molding under the door that runs down the very bottom of the car from wheel well to wheel well is hanging on mine. There are some clips that can obviously be removed, but the dealer says they don't exist. I even looked at his diagram with him and didn't see the clips, which is odd because I even pulled one out already. Anyone know of another car, Toyota or no, where you can get these trim clips that will fit?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 03-22-2007, 11:41 PM   #2 (permalink)
View GTO MAN's Photo Gallery
Mine were rusted very bad on the pass side itook it off and filed in the holes.
GTO MAN is offline   Reply With Quote
Old 03-23-2007, 03:27 AM   #3 (permalink)
Insanity makes more sense
View WVcamry3sfe's Photo Gallery
my car has the same problem.... saging side skirts...
do I hear the words epoxy coming to mind? :-D just glue it down to the car with some quality glue.
WVcamry3sfe is offline   Reply With Quote
Old 03-23-2007, 07:00 AM   #4 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I would recommend removing it completely, cleaning the trim piece and the metal underneath really well, then reattaching it with automotive grade 3M foam tape. That stuff is truly OEM grade adhesive.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 03-23-2007, 08:17 AM   #5 (permalink)
I was thinking this route but the clips go on the inside lip of the trim piece. I can't think of how to get tape in there in a way that it's going to reach the metal but not prop the trim off the car by 1/4 inch or so. Do they have any really thin tape like that?
Old 03-23-2007, 11:53 AM   #6 (permalink)
epoxy glue, such as jb weld is thinner than tape, and will secure your trim without any problem.... trust me, epoxy will last longer than tape will too.
Old 03-23-2007, 06:38 PM   #7 (permalink)
Gameroom cash: $302555
If it's anything like my generation 1, those clips are part of the molding. That piece is also pretty expensive. If I remember correctly, I paid about $125 for that molding, and that was around 15 years ago.
Mike
Old 03-23-2007, 07:01 PM   #8 (permalink)
HomeGrown's Avatar
No way, and I'd put money on it. JB weld or epoxy will work for a short time, but unless you sand it down to bare metal, it won't stick for long. This 3M automotive grade adhesive will NOT come off a clean surface, I've used enough of it on other cars so I know this to be fact. This tape is not thick enough to throw off the fit of that piece.
OEM grade tape is much more appropriate than epoxy, especially for a long piece of trim.
Old 03-23-2007, 07:13 PM   #9 (permalink)
HomeGrown's Avatar
The only disclaimer I'd have with the tape is that it would require at least a 1/2" wide contact patch with the car. If the trim piece only contacts the body with a thin edge, it probably wouldn't work well. The tape is pretty thin, about 1/16" IIRC. I've not had that piece of trim off my car, so I don't know where and how much it contacts the rocker.
Old 03-23-2007, 08:49 PM   #10 (permalink)
Ancientwolf13's Avatar
View Ancientwolf13's Photo Gallery
This will take a little bit of work, but take off the skirt completely, sand off any rust spots and fix them with body putty. Gets some small wall anchors galvanized or any rust resistant ones being the expandable kind from any hardware store. Drill a few holes as specified for the anchors to hold up the skirt. Before putting it back up make sure you use sealant on the anchor and in the holes to prevent any rusting from the drilled holes being exposed.
This can ba a permanent or temporary fix to change skirts later depending on how you decide to go about it.
I have done quiet a few of reattachments like this in my racing days
Ancientwolf13 is offline   Reply With Quote
Old 03-24-2007, 03:18 AM   #11 (permalink)
View car_boy_16's Photo Gallery
Pull out the rivet gun and just have at her. Stop f*cking around, this is a Toyota we're talking about.
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 03-24-2007, 06:13 PM   #12 (permalink)
All show, no go
marksktr's Avatar
View marksktr's Photo Gallery
i took both of my side pieces out, and dont need them anymore, i might be able to clean em up for yea, check em out, and sell em for a bit more resonable price then $125 a-piece.
not sure on how id ship em, but lemme know
otherwise id check out a junkyard, and buy em for like $10..
or do as i did, and take off theat piece, bondo the holes, and paint the bottom black...
tho my way is only temporary till i put on a body kit..
marksktr is offline   Reply With Quote
01 Solara chrome trim thatdamngood777 3rd & 4th Generation (1992–1996 & 1997–2001) 0 03-12-2005 05:28 AM
'Sup? 01 Camry Solara chrome trim anyone? thatdamngood777 Introduce Yourself Here 1 03-12-2005 05:26 AM
Trim Modification Speshull Droo Audio, Video, and Security - Tech 7 01-07-2005 12:48 AM
ugly wood trim on new Solara? rschleicher Solara 3 10-13-2004 11:01 PM
damnint...cracked trim around radio prophesized Camry & Solara Lounge 11 10-18-2003 12:22 PM
