Yup, the dome light switch works. I just talked to a mechanic and he said even though I changed post wiring on the motor to test the opposite direction, he said the motor would still run in the same direction, just that the belt/track goes opposite. He thought it was the motor that needs replacing, which apparently requires the "whole" assembly to be replaced. I not too sure of this and still think it's a much easier fix, such as ground to the door or something. It has to be electrical since the car doesn't get the message to reverse belt direction. Still looking for your expert help out to solve the issue there before I pay big labor fees to replace. Thanks.
