1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
My wife's 1990 Camry has dim headlights on low beam (she says high beams are all right, but I haven't confirmed). I have changed bulbs, reflectors and ground cable with no change in symptoms. Anyone have any ideas? The difference between the 1990 and my 91 is like night and day.
My alternator just went bad recently. I had the same dim low beams for a couple of weeks, then the "Charge", "Brake", and the tail light sensor lights all come on. I had the alternator tested, and it was bad. After I changed it, the sensor lights went out, and I had MUCH brighter low beams.
Beyond all good and evil lies North Dakota!
Garage: 2008 Toyota Corolla CE (1.8, 5 speed); 1978 Toyota Pickup (20R, 4 speed); 1989 Oldsmobile Cutlass International (3.3, auto, 2 door); 1988 GMC Suburban (454, auto, tailgate)
hmmm... i have that same "lights" sensor light on on my dash. when i fire up the car in the mornings or anytime throughout the day, the light is not there... but as soon as i press the brake pedal to operate the shift lever, it comes on. my headlights are fine, but, my rear lights seem faded, in other words they could be brighter... i haven't done an alternator check but i have a little volt meter i used to plug into my cig lighter port and it gave me a 14.xxx with the engine on. is my alternator goin too?
almost forgot, i did a diy alternator test, the one where park near a wall with the headlights on and the engine running, and i switched the engine off and the lights got just a bit dimmer. so i guess that would mean they're working ??
You should post a new thread for things like this...
Anyway... your alternator is fine. Check all your brake lights. If the rear light warning light illuminates, you have a bad bulb back there or a bad wiring. Only if the charge and ebrake light come on with it do you have a bad alternator.
-Charlie
-Charlie
lol, well my question was sorta similar, and since i did a search first i saw this was as close a discussion to mine.... well i'm glad, i'll have to go back there to check 'em , thanks charlie.
