Front Wheel Play - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2007, 06:56 PM   #1 (permalink)
View gspservice's Photo Gallery
2nd Generation Front Wheel Play
91 Camry when I grab the top and bottom of the left front wheel I can feel some play
it has a new tie rod and ball joint.Only thing I can think of is the wheel hub bearing how much trouble is it to pull.
gspservice is offline   Reply With Quote
Old 04-03-2007, 09:54 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
it's not too hard to pull.. just take off the whole steering knuckle few shields to take out first and you press it out.
Old 04-03-2007, 11:24 PM   #3 (permalink)
View toyomoho's Photo Gallery
Down load the bearing inspection data from the link below. You can put a dial indicator on the hub and check for end play.
http://oregonstate.edu/~tongt/camry
Old 04-04-2007, 01:35 AM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The axle nut may also be loose... Either way, the bearings are likely worn out.
-Charlie
Old 04-04-2007, 04:36 PM   #5 (permalink)
Thanks, my Haynes book didn't have a thing except take it to a pro. I haven't gotten into to it yet was working on something else when I noticed it.
Old 04-04-2007, 04:37 PM   #6 (permalink)
Good Idea will look up the specs on the nut and check it out
Old 06-04-2007, 10:36 AM   #7 (permalink)
View bestjudge's Photo Gallery
I have same problem(front drivers side)...I had somebody take a look at it and he told its $500 job including parts....bec bearing has to be replaced as an assembly! Iam looking to do this myself....what parts would i need, just bearing?Thx
bestjudge is offline   Reply With Quote
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
Front Wheel Hub in "Lock" While In 2 Wheel Drive lyons Land Cruiser Forum 0 01-18-2007 12:04 AM
Front Wheel Flutter gerryk Archived Corolla threads 9 12-17-2006 03:59 PM
noise in front end. whistlin_smithy Introduce Yourself Here 0 08-18-2006 07:15 PM
