1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
Can the suspension crossmember bolts be removed without requesting God's Hand from the heavens? I mean dang, in the Haynes manual there was an illustration of a person using regular hand tools so I guess it was somewhat easy. It would have saved me a lot of time, frustration and energy, I tell ya. Cheater bars didn't work and I snapped one of my ratchets, and that thing has loosened some TOUGH bolts. I need some air tools...
you need a breaker bar and a probably a pipe over the end of it for extra leverage if its being a pain. Impact guns are good too.
breaker bar isnt a ratchet, just a handle with a socket attachment on the end. if you use a regular ratchet with a pipe on it, youll break the ratchet everytime.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Wow, are they rusted or just torqued on there with The Hand of God? I've worked on a lot of rusty old Gen2's and never had a problem loosening them. An extension bar for 1/2-inch drive always works.
__________________ 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
Haha my terminology is off. Yeah I broke a breaker bar and used a one-and-a-half foot long pipe attached to it. I also used my weight training bar too (longer) and barely budged a millimeter. Does 1/2-inch make a big difference over a 3/8? Maybe it's all the PS fluid getting gunk on it. *sigh* Too late now, gotta do the other side tomorrow.
Holy jumpin' jahosifats, don't use a 3/8 drive! That's more appropriate for, say, unbolting fenders or radiator fittings--it's way too weak to remove a suspension bolt that's torqued on at 150lb-ft.
As far as p/s fluid, that would probably tend to lubricate the threads somewhat, likely making it easier to remove. And Tommy is right: be careful not to round-off the head, you don't want to be drilling and retapping a bolt hole that large.
Fred is right, don't apply so much pressure that you break the weld on the nut, that sucks just as much as a rounded bolt head. I would highly recommend an impact wrech. If you don't have a compressor, then get a electric impact, or try to rent one. Your chances are better with a impacting action to loosen the bolt, than to just use shear twisting force.
While we're on the subject of those peskywelded nuts, has anyone ever successfully dealt with that? I had it happen on the front end, where the hollow pan (the one that the stabilizer bar attaches to) bolts into the frame. I had to use a hole saw to cut the side of the frame out, so I could fix it. But with the LCA/crossmember mount on the frame under the passenger's feet, I just can't see how you could deal with that.
I'm going to be swapping the engine soon, and I just know it'll be a problem...anyone have suggestions?
Try a 1/2" breaker bar with a cheater pipe and a good socket. If that doesn't work go rent an impact gun and compressor or appeal to a mechanic to loosen them for you. But these are 150 ft lb fasteners. I had trouble believing how hard I had to strain when I used a torque wrench (also 1/2") to refasten them.
Alright guys, just installed both arms and went out for a drive. It's rough! I thought my wheels weren't tightened or something but they were. So I'm thinking this:
a. I have to wait for the components to "settle"
b. bolts too tight
c. bolts too lose
I'll check again tomorrow or maybe after a day of driving.
I gotta ask though, what components are torqued to 250ft lb? That's the highest limit I've seen on torque wrenches. Those must be insanely hard to get out.
