Auto tranny 1987 question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2007, 05:14 PM   #1 (permalink)
View Montanahelp's Photo Gallery
I have a 1987 3SFE with an auto tranny. It has about 165K miles on it. When I shift into DRIVE from a dead stop it takes a while to engage and go forward. If I manually shift to Low it takes right off. Any idea ideas?
Montanahelp is offline   Reply With Quote
Old 04-12-2007, 06:21 PM   #2 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
My, these cars do have their tranny issues, don't they?
Does it do this all the time, or only when cold?
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 04-12-2007, 07:07 PM   #3 (permalink)
Insanity makes more sense
View WVcamry3sfe's Photo Gallery
your tranny is beginning to show signs of age. it will be maybe about a year before you need a total tranmission rebuild. a140 and 140e transmission rebuilds cost about 1,700-2,000 dollars. So if you love your camry start saving money. If you want to get a different car, start saving your money. Don't neutral drop your car ever... and be easy when putting it in drive, give it enough time to engage before slamming down the throttle.
WVcamry3sfe is offline   Reply With Quote
Old 04-13-2007, 12:12 AM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Could it also be a shift linkage out of adjustment? I know on some Chevys that'll cause an engagement delay.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 04-13-2007, 08:19 AM   #5 (permalink)
It acts up when it is cold. Once it warms up it doesn't seam to do it.
Old 04-13-2007, 12:05 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
WVcamry is probably right. If you want to prolong the transmission life you may want to consider additives. That plus driving conservatively may extend your transmission's life until you're ready to unload the car. Cargo sells an "Automatic Transmission Leak Sealer" in the transmission to clean & "rejuvenate" the rubber parts. I think it helped my transmission (about 350,000 miles before it was totaled). There are others on the market.
Until you give up on it, baby it. I don't recommend flushing it until just before you accept the fact that you are going to rebuild or replace the transmission. Flushing the transmission seems to be a 50/50 proposition. Sometimes the fluid being forced through dislodges chunks that obstruct passages. Sometimes deposits in the various seals are what keeps a tranny functioning. Sometimes it cleans out a problem and helps.
I had a personal approach of draining the fluid (through the drain plug only) each time I changed the engine oil. Only two quarts drains out (out of the total of 12) so I figured it would freshen up the existing fluid without causing a major change. I used the high mileage type that had its own additives in it already. I only dropped the pan every 30,000 miles to change the screen. Worked for me but I have no evidence that it was a good thing to do.
The fact that it works better warm than cold makes me feel a little more optimistic about the cleaning rejuvenating additives. I don't know why but it seems right to me. Thinner fluid would flow through restricted passages better and the additive might clean out a residue/deposit enough to open the passages back up.
In the end, WVcamry made another good point. Start saving up your money. It the tranny craters you're going to need a nest egg. This also might be a good time to join AAA for their towwing insurance.
Best of luck,
Kep
94 5 speed 22re to older auto tranny swap subliminaltrips 89-95 Toyota Pickup/Hilux 0 01-18-2006 06:44 PM
2000 Av Auto Climate Control Question drizzle 2nd Generation (2000-2004) 1 12-03-2005 03:46 PM
1987 4cyl auto tranny no 2nd gear ThurzNite 1st & 2nd Generation (1983–1986 & 1987-1991) 8 09-21-2005 11:13 PM
94 auto tranny COYOTE556 Archived Corolla threads 2 06-01-2005 02:19 AM
tranny question karma Archived Corolla threads 9 09-06-2002 01:26 PM
