3sfe oil seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 10:18 AM   #1 (permalink)
View wiccanferret's Photo Gallery
3sfe oil seal
Both the cam and crank oil seals will not come out easily. I'm scared of gouging the metal. How do I get them out without damaging the engine?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 04-14-2007, 11:39 AM   #2 (permalink)
View nogard's Photo Gallery
Try using a seal puller? I think that the part that holds the seals unbolts, but you have to take the pan off to do that. Which isn't a bad idea since it probably leaks too. Then you can use a seal puller.
Otherwise you can take something sharp that is bent at a right angle, like a smaller pick. And you don't want to scratch the outer surface the seal sits in or the crank. But you can stab straight into the flat part of the seal and pull it out that way. But if it is hard to get out, you are going to have just as hard of a time getting one back in, on the car.
nogard is offline   Reply With Quote
Old 04-14-2007, 11:58 AM   #3 (permalink)
Tell me about it. We finally got it picked apart enough to pull out. Scratched the outside edge of the cam a bit but I don't think it'll make a difference. It's not like we had much choice. And you can punch through the middle of the camshaft seal because it's metal.
Old 04-14-2007, 06:30 PM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
My advice is little too late.
  • Get two sheet metal screws
  • Drive them into the exposed face of the seal 180 degrees apart.
  • Using nail puller bar or pliers, pull on the screw heads, alternating between sides in small incriments
The similar method is illustrated on the back cover of HAYNES manual.
Doctor J is offline   Reply With Quote
Old 04-16-2007, 08:41 PM   #5 (permalink)
Doc J, pure genius, simple yet effective.
Old 04-16-2007, 11:20 PM   #6 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Damn! That's good advice...I'll remember that one next time. Time and frustration saving...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 04-17-2007, 12:31 PM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The factory service manual (I believe) shows that you can cut around the inner part of the seal (the metal is on most of the flat part and the outer edge) and use that space to pry it out. I used a small drill to make a hole in the metal to help pull it out.
I like the sheet metal screw idea better though!
-Charlie
7AFE oil-burning knowledge pool Piloter 7th Generation (1993-1997) 13 02-29-2012 08:35 PM
3SFE Oil Leak wiccanferret Celica Forum 4 03-09-2007 05:37 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
