I believe Doc made a bushing that fit the I.D. of the manifold bolt hole (10.5 mm dia.). He then presumably drilled a 7/32 dia. hole thru the bushing, to guide the drill. This makes it possible to drill relatively closely into the center of the broken off stud. Without a bushing guide, the drill would more than likely wander to the edge of the hole and destroy the original threads in the head.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
