2G Rear Discs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 10:59 PM   #1 (permalink)
View stricular's Photo Gallery
2G Rear Discs?
So i have been wondering, what was the deal with the rear discs on 2G camrys? Was it part of a trim level package, a special separate option? V6 only?
And what is with the 15" steel wheels on some models? was there a big brake option or something?
stricular is offline   Reply With Quote
Old 04-14-2007, 11:03 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
only v6 had them .... all brakes are the same even v6 front is the same size as i4 fronts
Old 04-14-2007, 11:18 PM   #3 (permalink)
so can you put the rear discs onto a 4cyl equipped car? If so, what is required?
Old 04-15-2007, 01:06 AM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
http://tril.pendulus.net/reardiskswap.php here's my write up on my swap... have fun
Old 04-15-2007, 12:37 PM   #5 (permalink)
Thank you sir! Although i think i will choose not to use the cigarettes for the install. >
Old 04-15-2007, 12:42 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Ok... you mentioned braided lines in your writeup - where'd you have them made? Or are they from a Celica GTS or something?
-Charlie
Old 04-15-2007, 02:53 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
well technafit (http://www.techna-fit.com/) in torrance makes them.. for the fronts they have it... for the rears i brought them the OEM rubber lines and they made them while i waited (15-20mins or so)... or you can goto this place
http://www.hose-man.com/sys-tmpl/irwindale1/ in irwindale since you live by there charlie
http://www.hose-man.com//sys-tmpl/brakelinehose/ they also make them custom just bring in your rubber line but it takes them a few days though and they couldn't give me a price quote either :\ which is why i went the technafit way
Old 04-15-2007, 03:00 PM   #8 (permalink)
Pochacco Owns Me
atobe's Avatar
oh well one thing i forgot about my writeup was... if you chose to use the v6's hub then you only have to remove the 3 19mm bolts/nuts that holds it on and the brake lines... would probbly cut the time in half i bet
Old 04-15-2007, 08:41 PM   #9 (permalink)
white90dx's Avatar
Looks like technafit now has an application for the gen2 V6. Sweet. (listed as PN TOY-1022). Looks like I have a new part I need to get!
Swapping the whole rear V6 hub definitely makes the process easier, but you will need to do an alignment if you do it that way.
-Charlie
Old 04-16-2007, 07:04 PM   #10 (permalink)
Pochacco Owns Me
atobe's Avatar
^^ yeah that's the kit i ordered too but they sent me lines for drums in the rear that's why i went there... i guess i just have bad luck and got the wrong stuff
Old 04-18-2007, 01:32 PM   #11 (permalink)
Blazyntoyo
View 90camdx4's Photo Gallery
Canada
Not all v6 and i4 are the same, v6 with abs have the 277mm disc, same as es250, the caliper is the same , different caliper anchor for 277mm disc, i have these on my i4.
just need to do the rear to disc.
90camdx4 is offline   Reply With Quote
Old 04-18-2007, 04:11 PM   #12 (permalink)
View nuron's Photo Gallery
Wow I didn't know some Camrys had ABS.
nuron is offline   Reply With Quote
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
1996 Corolla rear lip or rear bumper (AE102) Jaspher Archived Corolla threads 2 11-24-2006 02:10 PM
Has anyone upgraded from rear drums to discs? DrRabbitFurHead 2nd Generation (2005+) 25 05-27-2006 10:06 PM
Rear Discs for Tercel? SkidPlate Tercel, Paseo, Starlet, and Sera Forum 2 09-12-2005 05:51 PM
sr5 to gts rear disc brakes drozy88d Archived Corolla threads 6 09-28-2004 09:17 PM
