88 v4 pulls left, getting worse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2007, 06:50 AM   #1 (permalink)
View cvandiv's Photo Gallery
2nd Generation 88 v4 pulls left, getting worse
my 88 (v4, auto, 154k) has always had a little pull to the left, but it's gotten worse recently. i replaced the front left axle about 4 months ago, but other than that, i haven't done any other work up there. it seems like its something an alignment just won't fix, am i right? what should i look for?
thanks!
cvandiv is offline   Reply With Quote
Old 04-16-2007, 12:04 PM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
look at your control arms and the tie rods, one might be bent. wouldnt hurt to take it to a shop that can do a computerized alignment to tell you where your wheels are pointed.
btw - its an i4, not a v4.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 04-16-2007, 01:58 PM   #3 (permalink)
Gameroom cash: $302555
Before you spend any money on the car, switch the 2 front tires with each other. You can do this yourself. If the car now pulls to the right, the tire which you just placed on the right side of the car has what is known as a radial pull. This is more common than people realize. The belts inside the tire shift to one side causing the car to pull to that side. That tire needs to be replaced. It's a good idea to at least replace tires on the same axle of the car (meaning front and back) at the same time, so you don't have 2 different tread patterns or 2 tires with different tread depths. This can cause some unusual handling problems.
If the pull is still to the left after switching the 2 front tires, then follow Tommy's advice.
Mike
Old 04-17-2007, 08:57 AM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
If the tire already worn unevenly on one side only, the pull direction would also reverse.
If the control arm bushing is worn, the alignment will not help. On the other hand, once arms and ball joints are replaced, and nobody tried to "adjust" alignment in order to compensate or cover-up, then after replacement the alignment re-setting is seldom needed.
Doctor J is offline   Reply With Quote
Old 04-24-2007, 11:09 AM   #5 (permalink)
View marc780's Photo Gallery
Mikes got some good ideas and thats how i always have to fix mine, swap tires until i find a pair the car likes.
Another possibility is that your left disk brake caliper is sticking. Next time you inspect the brakes, the pad wear will tell the tale - if the pads are worn evenly on both sides, then the calipers are fine. If the left side pads are worn more, replace/rebuild caliper.
Tire rumble during left turn or road curving left 5spd V6 ClrTail Camry & Solara Lounge 8 03-02-2005 06:24 PM
Left foot braking shwartz be with Hardcore Tech and Competition 3 01-12-2005 01:51 AM
car pulls to the left, alignment wont fix rustamabd Camry & Solara Lounge 12 08-08-2004 01:04 PM
front alignment issue - pulls to the left - HELP! rustamabd Archived Corolla threads 6 08-05-2004 02:48 PM
Car still pulls after alignment & wheel replaced SolaraTRD General Discussion 12 06-29-2004 10:03 AM
