Filling oil up in 1990 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2007, 03:47 AM   #1 (permalink)
View Spetz's Photo Gallery
2nd Generation Filling oil up in 1990 Camry
Just drained the gearbox oil on a manual 1990 Camry.
Just wondering where I fill it from?
I realise I should have checked from before... but I have done gearbox oil changes on other cars and the oil was on the gearbox casing.
Anyone can please tell me where to fill it from?
Thanks
Spetz is offline   Reply With Quote
Old 04-22-2007, 06:35 AM   #2 (permalink)
I am an idiot...
All I had to do is look better
Old 04-22-2007, 10:34 PM   #3 (permalink)
View dunksr71's Photo Gallery
I had the same proble so I got the manual. Its on the front of the gearbox hard to see behind the battery. I found it best to get at by removing the plastic panel underneath the car, 6 or 7 screws. I was a bit suprised to see red fluid come out when I drained it. Referring back to the manual it used auto fluid..
dunksr71 is offline   Reply With Quote
Old 04-22-2007, 10:35 PM   #4 (permalink)
ummm...
So hold on, do I gotta put auto fluid into it?
I put manual fluid into it???
Old 04-22-2007, 10:38 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
yes it uses ATF
Old 04-23-2007, 12:10 AM   #6 (permalink)
The manual recommends Dexron II or better, I was unsure so I confirmed it with a mechanic.
Old 04-23-2007, 01:44 AM   #7 (permalink)
Damn!
ANother oil change then
I used 80W 85 SAE oil
What viscosity do I use?
Old 04-23-2007, 02:27 AM   #8 (permalink)
I used castrol dexron III from super cheap, I think, I don't think it has a viscosity rating.
Old 04-24-2007, 11:00 AM   #9 (permalink)
View marc780's Photo Gallery
ALways Remove Filler plug BEFORE Draining FLuid.
Helpful hint, ALWAYS find out where the filler plug is, and REMOVE IT, BEFORE you remove drain plug! If you cant remove the filler plug to put in the fluid, then what are you going to do, set the car on its side?
Youd have to drill it out if you could even get a drill in there, which is doubtful....so just remove the drain plug first. I have had many if not MOST of the drain plugs on manual trannys, turn out to be so tight from the factory that it took me DAYS of trying to get them out! Also they are easy to strip the head. If you do this before you drain the oil, no big deal after all. But if you do it after the fluids out...no way to get the fluid back in, gravity being what it is.
Old 04-24-2007, 01:09 PM   #10 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Originally Posted by Spetz
Damn!
Unless you have a V6 manual (which uses normal gear oil).
Some on the forums have had perfectly good luck with gear oil in the 4-cylinder manual transmission. If you aren't grinding into gears and the tranny feels good, you should be fine with the gear oil as it is. I don't have first hand experience though...
-Charlie
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Oil changes on my 07 Camry jshtick 5th & 6th Generation (2002-2006 & 2007-2011) 26 06-26-2006 09:52 PM
About Oil and Gas for 2005 Camry V6 liuhais 5th & 6th Generation (2002-2006 & 2007-2011) 43 12-03-2004 09:24 PM
