sv21, 3sfe 1988 wagon - cartridges or struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2007, 08:18 PM   #1 (permalink)
View jtu100's Photo Gallery
Australia sv21, 3sfe 1988 wagon - cartridges or struts?
Hi,
I have a 1988 Camry, SV21/3SFE, Australian, Station Wagon.
I am wondering if the suspension struts are serviceable or not?
Someone on ebay is trying to sell me some cartridges (Delco GC139) for my Camry, but the service manual seems to make out the strut is a non-serviceable unit.
Is the cartridge seller confused?
Or is there a way to fit these to my car?
Thanks
jtu100 is offline   Reply With Quote
Old 04-22-2007, 08:27 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
it came with both.. you'll have to take a look on your strut and see if there's a big nut on it or not.. if it does then it's serviceable if it doesn't then you have to replace as a whole
http://www.toyotanation.com/forum/t154557.html for pics
atobe is online now   Reply With Quote
Old 04-22-2007, 08:29 PM   #3 (permalink)
Or is there a way to convert to cartridges?
I wouldn't mind as they are supplying the cartridges, new, for $25 each!
Old 04-22-2007, 08:44 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
you can goto the junk yard and just take the casing i suppose and use the inserts(cartridges)
Old 04-22-2007, 08:44 PM   #5 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
got a grinder and a welder?
youll have to cut the top off the strut, pull out the inards, then weld it back together. Lot of work to save $100.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 04-22-2007, 08:44 PM   #6 (permalink)
Just checked my struts. They appeared to say this on them:
TOYOTA
-T202 48 102-
-=MONROE D05 AU88=-
GAS PRESURISED
DO NOT HEAT OR PIERCE (?)
The top piece ("suspension support" its called in the service manual) had part number: T202 48 114
Old 04-22-2007, 09:00 PM   #7 (permalink)
I've looked at those pics and I can see a big nut.
So I've opened up my engine bay and I can see the suspension supports with a little dust cover that I can open. Inside I can see a large nut.
Is that the same nut as in the pics above? Or is that nut meant to be visible immediately inside the engine bay i.e. no dust cover?
I just spoke to a suspension guy and he was insistent that my camry was 'inserts' i.e. cartridges. He seemed quite confident!
Old 04-22-2007, 10:35 PM   #8 (permalink)
Pochacco Owns Me
atobe's Avatar
the nut you saw is the one that holds the strut to the car if he's so confident then he won't mind to give you $ back if it's not the right part
Old 04-24-2007, 03:08 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Theres more to it then just cutting the strut open and welding it back together. You have to weld another piece of pipe onto it, this pipe is threaded on the inside. A big nut screws onto those threads. Serviceable struts already have the threads and the big nut.
I don't remember the site offhand, but I do remember seeing something about the modification. It was done on a Celica.
No, that nut holds the strut to the strut mount.
You need to look at the strut itself. At the top of the strut housing where the piston shaft (shiny metal shaft) goes in. It'll be covered up by a big dust boot, just lift the boot up and look.
"Skoolin' the unlearned!"
Old 04-24-2007, 09:10 PM   #10 (permalink)
Are you talking about the area I've marked in red below? I have checked my struts and there is a sort of hexagon 'bolt' at the top of the strut body. But how can I be absolutely sure they are serviceable? Does anyone one have a closeup pic of serviceable vs non-serviceable?
Toyota Camry 1988, SV21, 3SFE, Station Wagon
Sydney, Australia
Old 04-24-2007, 10:14 PM   #11 (permalink)
Pochacco Owns Me
atobe's Avatar
here i took a pic of my old strut
[img=http://img401.imageshack.us/img401/8638/img0892zq3.th.jpg]
i don't have a pic of a sealed one.. but instead of the nut you should see welding marks around the place
Old 04-24-2007, 11:15 PM   #12 (permalink)
We are talking about the rather large nut just under the piece of string (?) on the right strut in that pic ... right?
Sydney, Australia
Old 04-25-2007, 12:01 AM   #13 (permalink)
Pochacco Owns Me
atobe's Avatar
yes both of them are serviceable.. if it's not you wouldn't see that big nut there
Old 04-25-2007, 12:46 AM   #14 (permalink)
If I do end up having serviceable struts, am I going to need any other parts when I swap it out? New nuts etc.
The tops of your inserts look a bit different to the ones I'm planning to buy off ebay...
http://cgi.ebay.com.au/HOLDEN-APOLLO...QQcmdZViewItem
Sydney, Australia
Old 04-25-2007, 12:56 AM   #15 (permalink)
Pochacco Owns Me
atobe's Avatar
what top? you take off the big nut... remove the insert and put in the ones on ebay put the nut back on and you'r good to go
1988 Tercel DX Wagon 4E-FTE Swap Possible [?] Al_88DXWagon Tercel, Paseo, Starlet, and Sera Forum 5 05-01-2005 05:52 PM
Struts For My ae92 Wagon.... Spud Archived Corolla threads 20 04-05-2005 06:49 AM
Will the GT4 manual box fit in the SV21 and on the 3SFE? the_beast Camry & Solara Lounge 3 04-27-2004 12:43 AM
